- Dec 31, 2010
- 3,099
- 7,551
- Frankia Platin i7900
- Since 2010
First outing is St George,s bash Jim, you could use a double pole mcb to kill the solar get one for a few quid
We are on that as well,see you thereFirst outing is St George,s bash Jim, you could use a double pole mcb to kill the solar get one for a few quid
Yeah that's right, but my victron smart solar mppt also has the ability in the Bluetooth app (victron connect) to turn the charge off as wellWe are on that as well,see you there
In your set up you had a big isolator switch for your solar. Is that what you use it for to turn the solar off to prevent the lithium battery from fully charging when the van is not being used?
I don't think it will work unless it's an AES fridge. The Votronic controller switches in ½ hr block so as not to flatten the batteries the fridge does ½ hr 12v then swaps to gas & ½ hr later back to 12v. Also the fridge needs a permanent 12v supply.Thank Lenny will check the controllers for that AES out ,is it just a case of connecting to the S= terminal directly.? My fridge is a dometic RMS8501 series but manual switch over.not sure where that terminal is currently![]()
Thanks Lenny, I checked the fridge this morning and there is an s+ terminal but it's positioned between the vents and not readily accessible unless I disconnect the gas and pull the fridge back into the van.I don't really want to do that and disturb all the seals. I see your point re the gas coming back on after the 12 v switches off.I don't think it will work unless it's an AES fridge. The Votronic controller switches in ½ hr block so as not to flatten the batteries the fridge does ½ hr 12v then swaps to gas & ½ hr later back to 12v. Also the fridge needs a permanent 12v supply.
Just had a look at the install manual, it's not clear, I did notice it's a caravan fridge not a motorhome specific fridge.
The S+ will be in the main connection block, the problem I can see is without AES when the signal from the controller turns off the fridge won't switch to gas.
Thanks,I intend to do that as I thought it should be much higher than the few amps ,we have noticed ,but that was only monitored off the lithium battery BMS .I assumed because the lithium was always showing 13.4 v that the "system" was showing the battery as fully charged.I have just fitted 150ah lithium, coupled to one 110ah LA with isolation switch, to disconnect the lithium when it reaches required SOC I'm watching this config closely. only done 5 cycles thus far..
I just tried disconnecting my B To B to see what the charge rate would be, this turned out to be around 55 amps.
So I'm thinking maybe Jim you need to check your alternator output as it seems rather low
Likewise I have fitted a switch on the D+ signal to the B2B so that I can turn it off when I am happy with the SOC of the hab battery. It's easily accessible whilst driving so can change the setting on route. At this time of year I'm finding that solar is doing fine at topping up.trouble is, if your battery is always full your not gonna see any alternator action, as your batteries are not calling for any power. try pulling the solar fuse and run battery down a bit. then you'll see on bluetooth how many amps are going into lithium. I'm using my B to B to limit alternator charge into lithium, as I'm told lithium will take whatever the alternator will give,
thus burnout alternator. although in practice I'm not finding that to be so. but I am still monitoring it
Due to potential gas shortages ,I was looking to try that with my fridge but it's not an auto fridge ,but will run from the alternator when the engine is running,as it's supposed to do.On sunny days I have been manually turning our large gas thirsty fridge from gas to battery once the SOC is over 80% & turn back once down to 65%. I have a warning sign to remind me it's on battery. This seems to work fine.
I was really thinking of using the excess solar we have rather than see it wasted. My lithium battery has just started to showcase discharge from the 100% soc it was on at 5 oclock and we have had the TV on since then.its now just dropped to 99% because the sun is going down.Whilst I think it's a really good idea to use excess solar to reduce gas use I suspect its unlikely to be a big enough gas saving to repay the cost of solar and battery cost.
