You can plug the power pack into the EHU inlet using a wire with a blue socket on one end and a plug for the inverter on the other. You could keep the power pack inside, and run the wire through the door.
If you have an AES fridge you may have to manually switch it to gas, otherwise it will automatically switch to 240V and drain the power pack in a couple of hours.
An alternative to blanking off the pins on the EHU inlet is to wire a changeover switch to swap between EHU and Power Pack. Similar to the arrangement for a built-in inverter or generator. Then you can use EHU if you want, to charge up the power pack for example.We almost never hook up to mains as we Aires/BritStop/FrancePassion/Stellplatz, so I am going to hardwire it into the van via the 240v input cable so that it keeps the other batteries topped up via the [Broken Link Removed]. Also all 240v sockets will be usable throughout the van without hookup. I may switch the 240v breaker for the fridge off and just keep it as 12v or gas AES.
Simple solution, I hope. It will also charge all the bikes , tech, tools etc in the garage. I plan to blank off the pins on the ehu so they cannot go live from the Delta.
