Have you used it as a EHU hook up?Yes I have an Ecoflow delta. It’s very good,and main advantage over other makes is the speed it can charge.
How did you connect to your 3 pin hook up?Yes I have,the last time we were at a ths and there was no sun for my solar and worked very well.
Yep, me. I have an Eco Flow River Pro with a 160w solar panel. Bought this and also fitted solar to the van to make life easier when off grid - ie most of the time!Has anyone invested in an Eco Flow battery setup?
Jo662 This may sound dim, but I'd not considered actually 'plugging my van into the Ecoflow'. Just plugging in the various items I use directly to the Ecoflow. Do you have a short cable with EHU van socket on one end and 3 pin plug on the other? Doing this a couple of times a day for 20 minutes would give me a tank full of onboard hot water, which is a nice thought and currently the ONLY thing which EHU gives me which solar/the Ecoflow doesn't.Yes I just plug into the 3 pin socket on the Ecoflow to the EHU.
I have both a LiFePO4 setup in my motorhome and a Bluetti so perhaps I am in a good position to comment. If you intend to use the portable power station at home and other locations as well as in your motorhome then it may be a good option. However if it is solely for motorhome use then I think you will probably be better off with an onboard LiFePO4 set up. The £ per Ah is worth thinking about.I am looking at whether the ecoflow type option is better than a full lithium/solar upgrade....
Just got the delta mini, fits under our bench seat and as the hook up socket is in a locker can connect it to the EHU, switch on and have our 240v sockets live without even going outside whenever we want. Helpful when off grid and will also charge main battery if that gets low. Haven't got a solar panel for it yet as all Eco flow ones out of stock so looking for alternatives. Can still charge it when driving though using cig lighter socket and can make sure it's topped up when on site EHU.
I got my RIVER with a discount thanks to a YouTuber I follow who reviewed it. Their code has now expired, but it may be worth looking for DELTA reviews and seeing if any of them have discount codes.Just waiting for the summer sale (no date given but its soon and I'm on the mailing list to find out). I'm going for the Ecoflow Delta, plus panels.Seems to be the best all rounder for me.
Yup, they have all moved allegiances from Jackery to Ecoflow.Loyalty is brief where freebies are concernedI got my RIVER with a discount thanks to a YouTuber I follow who reviewed it. Their code has now expired, but it may be worth looking for DELTA reviews and seeing if any of them have discount codes.
True, but in this case the YouTuber concerned didn't get their RIVER as a freebie, they bought it.Yup, they have all moved allegiances from Jackery to Ecoflow.Loyalty is brief where freebies are concerned
Good to hear.The Ecoflow clearly has some advantages over the others so credit card ready for the summer sale.Hope they don't all then start bringing out LiPo4 versions just as I make a long term investment.True, but in this case the YouTuber concerned didn't get their RIVER as a freebie, they bought it.
Quite possible now that Bluetti are doing so for some of their models.Good to hear.The Ecoflow clearly has some advantages over the others so credit card ready for the summer sale.Hope they don't all then start bringing out LiPo4 versions just as I make a long term investment.
Think I know who you mean. They are always clear about if they get given stuff and if they buy it. Shame others don’t make it clear for all to see.True, but in this case the YouTuber concerned didn't get their RIVER as a freebie, they bought it.
I just bought an EcoPower Delta. I already had two 150w solar panels I had bought for £200 the pair. EcoFlow provide the lead you need from RC4 to Delta. Excellent. I read that connecting in series doubles the voltage whilst keeping the current down to below 10Amps (which it needs). By going in series, to 50volts, (10-95v are acceptable), it registers the watts plus calculates the time to charge. Regularly getting 280watts which charges really quickly.Just got the delta mini, fits under our bench seat and as the hook up socket is in a locker can connect it to the EHU, switch on and have our 240v sockets live without even going outside whenever we want. Helpful when off grid and will also charge main battery if that gets low. Haven't got a solar panel for it yet as all Eco flow ones out of stock so looking for alternatives. Can still charge it when driving though using cig lighter socket and can make sure it's topped up when on site EHU.
Very interested in how you connect direct to your ehu socket.240 volt speed of charge is so good compared to my Jackery 1000! I bought a Delta Max a few weeks ago and used it as a EHU yesterday for the first time. Sherwood Pines this weekend also for the first time. After Friday night on my LiFePO4 110AH leisure battery (240v dog fan running all night) I woke up to only 30% power remaining on Saturday morning, so then I needed EHU due to lack of sunshine. I plugged in the Delta Max (I have a short EHU lead running through the floor that allows hook up with the Battery inside the cab). The 300 watt solar panels only recovered the LiFePO4 to around 70% before before sunset. This morning I woke up to 50% on both LiFePO4 and the Delta Max, which I was pretty pleased with. When I got home I plugged in the Delta Max into the mains and it was charged back to 100% in around 50 minutes which opens up so many quick charge options compared to the Jackery that you'd have to leave unattended for hours to get the same charge. Solar and 12 volt charge on the Delta Max is the same slow process as the Jackery unless you have a huge solar array, but the 240 volt charge is a game changer for me, although a bit bulky to charge at the local pub whilst having a beer, but I'm sure it could be done!
Remember a 600W microwave needs a lot more than 600W to power it. 600W is the heating output not the electrical input.an inverter to power a small rice cooker or 600w microwave?
These have an inbuilt inverter so if you connect the 240v output to your van’s 240v input the van will work just the same as if on EHU as long as there is charge and you don’t exceed maximum load capacity of the inverter. So yes you 240v sockets can be used within that capacity and yes you can top up your onboard lead acid battery via your existing charger. But you will eventually run out of charge unless you top the new battery up either from mains, solar or 12v while driving.Ok, so a question from a complete numpty but very interested motorhomer who has a single lead acid 100amph leisure battery and has been considering a portable solar panel, to give a little more piece of mind when occasionally off grid or on a ths.
Fitting lithium is not an option on a 22 year old van as too much reworking of cables is required plus charging units, plus , most importantly, cost.
A lithium battery alone is sub £700.
Will one of these power stations be ok connected to MY ehu connection to power my 240v sockets and will my lead acid leisure battery be ok being charged from said portable charger which is lithium?
Very very interested in this possible system as it could possibly remove the need for either 2 lead acid 12v batteries ( only have space for 1) to give me sufficient capacity and the need for an inverter to power a small rice cooker or 600w microwave?
Look forward to any help.
