eBike battery won't charge (4 Viewers)
MattR
4,170
42,693
Beds
Panel van
Years
Hi,
I have a 36v 8.8Ah/316Wh battery that isn't charging. I used it frequently last summer and have had it in store since then. I think that I charged it at Xmas time even though the lights on the battery suggested it was still fully charged. Now the lights show it at 20% and it won't charge. I can't recall if I've had it at 20% before and have not checked the voltage from it yet. The bike control panel doesn't come on now either.
When I have had car batteries that have dropped too low to charge with a normal charger, I've used a pulse charger to start the process and it then reverts to a normal charge.
If I cut the charger wire of the charger and connected it to the vehicle charger with pulse function to get it to start charging and then continued with the original charger, am I likely to cause a dangerous situation? Is it likely to get it back to a chargeable state?
Thank you
CAB96
1,234
2,370
Stockport, UK
T6 Leisuredrive
What voltage does the charger provide?
Have you tried using it for a bit to jog the battery in to life?
suavecarve
8,274
42,063
Surrey/Hants
Dethleffs Trend A
July 09
I have no idea either but .......................... when my drone battery hadnt been used for a while I had to buy a specific connection to get the charging process working again.
Whether that is the same or not I have no idea
Jan 30, 2020
3,519
16,712
Mid Bedfordshire
RS Endeavour
Just a tad..
What’s the voltage showing on the battery terminals with a volt meter?
If low, I’d connect it with a charger that can bump up the voltage first in the wrong profile, like non lithium, Pb would work, then switch back to your normal charging method.
May 7, 2016
7,861
13,248
West Sussex
Malibu Van 640 LE K
Since 2003
Would a 12V Pb charger even register on a 36V battery? It doesn’t sound right to me.
Ridgeway
3,883
7,013
Lausanne
NiBi Arto 85E
Are you sure the charger is working correctly ? Any way to test either another battery or another charger to see where the issue is ?
Nov 27, 2011
17,851
44,358
it is highly likely one or more of the batteries internal to the battery pack has died and the internal battery protection circuit has triggered, preventing charging. A very common fault, and the battery needs refurbishing or just replacing. Don't attempt to force a charge in
Jan 30, 2020
3,519
16,712
Mid Bedfordshire
RS Endeavour
Just a tad..
Good point.. I forget myself sometimes… 🤦‍♂️
I have an iCharger which is for the serious hobbyist market and allows complete configuration of charging parameters, how many C charge rate, voltage, Amps, battery chemistry etc ✔️
MattR
MattR
4,170
42,693
Beds
Panel van
Years
The charger is outputting 40v - the label states 42 v
MattR
MattR
4,170
42,693
Beds
Panel van
Years
The battery starts at 3v and drops to 1v quickly.
MattR
MattR
4,170
42,693
Beds
Panel van
Years
Is that likely to have been caused by lack of use / charging or age? I'm guessing the battery is approx 8 years old.
Nov 27, 2011
17,851
44,358
The batteries have a service life dependant on which manufacturer. After 5 years it is just chance which fails first.
Yes you can replace the cells in some battery packs. Never be tempted to do just the failed one as they tend to fail again and again and can kill the new batteries.
Often see this after leaving them dormant for a few months and the protection circuit kicks in at the first charge cycle.
What I hate is some manufacturers make the protection circuit to fail killing the charging chip, which usually has the markings sanded off to prevent replacement
Mar 16, 2016
1,075
6,622
Norfolk Riviera
Hymer S520
Beware of cheap Chinese E-bike batteries.
Dec 19, 2020
3,923
10,608
The salty bit of Hampshire
Since 2017
I've had our e-bike batteries refuse to charge. I've managed a workaround by using the supplied charger but connecting a couple of wires with plastic tape and a crocodile clip and using the bare ends to attach to the + and - prongs that connect to the bike socket. A short while 20-30 mins is usually sufficient to then enable normal charging. Needless to say, do not leave unattended for too long in case of problems. I do mine in the garage close to the door so that it can be evicted quickly ICON.
