Hi,
I have a 36v 8.8Ah/316Wh battery that isn't charging. I used it frequently last summer and have had it in store since then. I think that I charged it at Xmas time even though the lights on the battery suggested it was still fully charged. Now the lights show it at 20% and it won't charge. I can't recall if I've had it at 20% before and have not checked the voltage from it yet. The bike control panel doesn't come on now either.
When I have had car batteries that have dropped too low to charge with a normal charger, I've used a pulse charger to start the process and it then reverts to a normal charge.
If I cut the charger wire of the charger and connected it to the vehicle charger with pulse function to get it to start charging and then continued with the original charger, am I likely to cause a dangerous situation? Is it likely to get it back to a chargeable state?
Thank you
Thank you
