dumping water
thanks for everybody’s help rang seargent who make panel above door and told me of manual way of opening valve a little turn button on top of valve so that will get me away for now and it’s booked in for fixing. thanks again
I’ve got the same system, the tank level indicator’s are unreliable open the waste dump valve and run water down the sink to see if the water runs out.
If not on mine’s the valve is on the end of the line and you can pass a stick or bbq skewer through the valve to prove it’s open and not closed,If it’s open that would suggest you have a blockage in the pipe work.
Hope this makes sense,good luck.
will have a look at valve tonight. not got a tester or how i would use it. hoping there would be a mechanical override still under warranty but booking in is weeks away was going to scotland in 2weeks xxcxffcx
A cheap multimeter (so you can check voltages) is pretty much essential. Plenty on Amazon and the first step for investigating loads of issues - highly recommended.
I think there was a previous thread regarding the swift dump valves failing on a regular basis
Just more complicated electronics. What was wrong with the old manual system. All these bits are going to be expensive to fix out of warranty.
