The other one is almost identical but an exclamation mark ! instead of an OFFThe one on the right is telling you collision avoidance is turned off. Can't see the other one too blury.
Quite normal for a Mk 8 with the driver assist system, and It's a warning to tell you that the emergency braking system is off line.. Expect this to happen when your windscreen has been fogged up (as per normal when camping without a screen cover on and you get condensation), or in very heavy rain or with a dirty windscreen in front of the camera. This is due to the front camera (located in the black box where the rear view mirror should be located) being obscured by "atmospheric conditions" and it does not like that. It will also go off in very strong and low sunlight.These 2 orange warning lights have been appearing intermittently ever since I got a Fiat Ducato S8 last year. At top of speedo and generally both of them together as in photo. Mostly in rain with traffic. Any idea what they mean? Should I be reporting them to Fiat as under warranty?
RRD. Ricochet Reduction Device?Strange thing is it only works after you to have hit something it puts the brakes on to stop you bouncing off and hitting other vehicles. Well that's the way I read it.
That's what I thought until I read Fiat's description of it I think it's was in their website.Where have you read that?
Such systems normally use the parking sensors to detect if you are going to stop in low speed manoeuvres and if you ignore the warning apply the brakes.
It applies brakes when the frontal camera detects an obstacle, before crashing.Strange thing is it only works after you to have hit something it puts the brakes on to stop you bouncing off and hitting other vehicles. Well that's the way I read it.
Mine has triggered a few times, mostly when cyclists or pedestrians appear from nowhere or often when it sees a car parked on the offside but can't see the left hand bend that I am about to go around and thinks I am going to go straight ahead and clout the car, as I have not come off the throttle. This results in a BIG noise, flashing warning notice and as I have usually already reacted to the hazard, I have never been aware of the brakes coming on.It applies brakes when the frontal camera detects an obstacle, before crashing.
I have a pioneer radio head unit so there are no menu links via radio as with a Fiat head unit. But I can turn mine off by using the menu buttons on the steering wheel.I wonder if there's a way to turn it off?
