Ducato semi air valve has sprung a leak what are they called
Northampton
Rapido & Bongone
I have one leaking valve, bags are OK they both hold pressure with the good valve)
What are they called? where am I likely to pick one up tomorrow (going on Saturday) if push comes to shove I've got a T connector.
If your talking about the valve where you blow up the air bags, they're called Schrader valves. I know you can et them from Marcle leisure.
the nearest description
is schraeder inflation valve 1/8" npt female.
what is NPT ?
other advert descriptions include push fit Pneumatic air water npt threads.
thanks, precisely what i want but before early early saturday morning.
Schrader valves generally only leak from the core which is replaceable or if it has worked loose. Get yourself a kit like the one in the attachment, or call in at a friendly tyre spot and get them to check it out. My neighbour's car tyre had a "slow puncture" a bit of spit across the top of the valve indicated a loose core, 2 minutes to tighten it up !
You might get a tool and core from Halfrauds ?
Thanks for all suggestions and info
If it was like a normal car or push valve it would have sorted it ,not seen one quite like it.
Any ideas, at least I got a day more than I thought I had , today is Thursday not Friday?
Marcel leisure guarantee next day delivery?
Just 2 minutes from my son popped in , no luck, all sorts of air stuff this too specialised.try a car factor
Car factor too specialised
Can't see it on website and get answering machine.
In spite of best efforts from you lot no luck yet .
I've fitted the t piece and done a short test run ,
time for a cup of tea and bell Marcle again
