- Sep 23, 2013
- 2,645
- 10,374
- Globecar Campscout
- Since 2008 (started in a VW T4 campervan)
The sliding side door on our Fiat Ducato PVC has become very stiff & squeaks & squeals. As far as I can tell, it is the runner in the middle of the door that is the problem. This appears to be a rubber or plastic wheel running on a stainless steel runner. The whole assembly is mounted on a pivot that rotates through about 90 degrees as the door moves out from the side of the van & begins to move rearwards.
It is difficult to tell if it's just the wheel that is the problem, or if the pivot may also be stiff. It is inclined to jam just as the door has moved out & starts to go backwards, but if the wheel is sticking, this may be what it hindering the rotation too.
Anyone had similar problems & if so, what was the cure? Given the mix of materials & the fact that the runner is exposed, so getting it greasy doesn't seem to be the right option, I'm wondering what, if anything, can be used as a lubricant.
As I'd like to keep this visible & therefore out of the Belly Locker, please resist the obvious temptations at least until after I've had the sensible answer.
