Ducato oil change. (3 Viewers)
May 29, 2014
2,143
1,755
southampton
A frame
since 1985
Having a problem finding info on how often gearbox oil should be changed, quantity and grade.
Has anyone carried this out.
Feb 22, 2011
10,153
21,064
Newcastle under Lyme
Hymer B544 A Class
Engine and year ?
On mine it's not a service item and no level plug or dipstick so I changed it myself.
A year later it needed a new clutch so got changed again.
43,561
51,342
Engine and year ?
That's extreme and unnecessary.
Why did you change oil while changing the clutch.
The clutch is dry so no need to change oil.
Gearbox oil change is usually very high mileage....maybe 80000 to 100000 miles or more.
Dec 2, 2019
4,281
9,606
South Lincolnshire
Rapido 7065+
Broken most bits now
The driveshafts need to come out to remove the gearbox for a clutch change so the gearbox oil comes out anyway. No point in trying to reuse it
Sep 28, 2015
2,117
2,747
Hymer B544
2001 Caravans 2011 Motorhomes
2 3l 130 hp 2009
I changed our 2014 X250 Ducato six speed gearbox oil 18 months ago at 24k miles just to be sure I knew what was in there. There’s a thread about on here. I used Petronas Tutela Matryx fully synthetic and put 2.9 litres in.
Can’t be sure about the 2009.
pelican
May 29, 2014
2,143
1,755
southampton
A frame
since 1985
Was the oil contaminated visually?
Sep 28, 2015
2,117
2,747
Hymer B544
This may be of interest too.
Nov 10, 2013
437
1,131
Started in 2013
Changed mine last year at 100,000 miles oil was very black and did not look very nice, I also used Petronas Tutela. Easy home job, filling is done through the breather.
Feb 22, 2011
10,153
21,064
Hymer B544 A Class
Not sure of the setup with the Fiats, but make sure you can access and undo the fill point before you even try to undo the drain plug !
Access isn't too bad but you need to remove the air filter housing and the breather clips off to allow filling.
