Having a problem finding info on how often gearbox oil should be changed, quantity and grade.
Has anyone carried this out.
That's extreme and unnecessary.Engine and year ?
On mine it's not a service item and no level plug or dipstick so I changed it myself.
A year later it needed a new clutch so got changed again.
The driveshafts need to come out to remove the gearbox for a clutch change so the gearbox oil comes out anyway. No point in trying to reuse itThat's extreme and unnecessary.
Why did you change oil while changing the clutch.
The clutch is dry so no need to change oil.
Gearbox oil change is usually very high mileage....maybe 80000 to 100000 miles or more.
2 3l 130 hp 2009Engine and year ?
I changed our 2014 X250 Ducato six speed gearbox oil 18 months ago at 24k miles just to be sure I knew what was in there. There’s a thread about on here. I used Petronas Tutela Matryx fully synthetic and put 2.9 litres in.2 3l 130 hp 2009
As said ,drive shafts have to be removed so oilhas to come out ,might as well use new.Why did you change oil while changing the clutch.
Was the oil contaminated visually?I changed our 2014 X250 Ducato six speed gearbox oil 18 months ago at 24k miles just to be sure I knew what was in there. There’s a thread about on here. I used Petronas Tutela Matryx fully synthetic and put 2.9 litres in.
Can’t be sure about the 2009.
Gearbox filler / breather?
Found a small oil leak from one of the driveshafts a few weeks ago ( 2018 Ducato 2.3) so took it to our local Fiat Professional and they replaced the seal. Great. Took the van home and it has been parked for just over a week on the lawn. I moved it on Saturday and found an oil patch on the...www.motorhomefun.co.uk
It looked dirty, not quite black and had tiny metal filings on the drain plug magnet.Was the oil contaminated visually?
Access isn't too bad but you need to remove the air filter housing and the breather clips off to allow filling.Not sure of the setup with the Fiats, but make sure you can access and undo the fill point before you even try to undo the drain plug !
