Ducato cam belt change.......confused. (2 Viewers)
May 19, 2020
205
248
Knaus Sun Ti 650 MEG
Since 2020
Spoke to my local independant a couple of months ago as mine will be due next year.
They won't use Gates any more as they and other workshops have had problems with both Gates belts & water pumps, they will now only use Fiat kits. The price of Fiat kits has rocketed in the last year now £400 + vat = £480 just for the kit & the best part of a days labour so around £800 maybe more.
Hi Is this the correct OE part??
RM_Marine
684
1,174
Poole, UK
Autotrail Apache 700
Since 2021
So going by that do I need to get mine done as its a 2014 auto trail apache 700 with 7k miles on 🙄, I'm neither light or heavy use 🤔
Feb 19, 2020
1,441
1,584
North Ayrshire
Adria Matrix 670SC
Saying they will inspect it goes for nothing, It's not just wear that causes the problem. They don't just snap either. What happens is one or more of the teeth break off and the engine looses timing.
53,764
151,286
RM_Marine
684
1,174
Poole, UK
Since 2021
What's the new price 🙄
Jun 16, 2014
656
2,440
NOTTINGHAM
Autotrail Savannah
Almost a Newbie but not quite now.
The Gates replacement kit - belt and waterpump costs in the order of £235 - £245 on eBay, so I'm assuming with at a quote of £350 , the waterpump is not being replaced.
No the water pump and all pulleys is being replaced..... full kit.
Looking at the last change of belt done before I purchased the van,,,,, 3 hours labour was invoiced.
Yes. My mechanic says at 33k miles my 10 year old van is classed as light and standing is worse than working it.
53,764
151,286
Last time I had my FIAT 2.8jtd timing belt changed at 5 years the garage showed me that the old one was already showing signs of wear, so I am sticking to 'every 5 years'.
He said then the water pump looked fine, but next change that will be done also.
I trust my guy because he has had more vans through his workshop 'than you have had hot dinners.'......[Think that is a Northern expression ]
Geoff
Water pump not driven by the cambelt on the 2.8 so not necessary to replace it.
My tame Russian did mine last year.. £180 inc full kit ( but he does look after me cos I work on his bikes when needed )
The 2.8 is far cheaper to do than the 2.3 multijet, that is the price a friend paid the mobile guy I recommended about 4 years ago.
53,764
151,286
Or your friendly mechanic is making a fortune. Don't forget they also get a trade price :unsure:
I expect they quoted retail, if they didn't make a profit they wouldn't be in business.
I used to trade a lot on ebay and was always coming across suppliers who weren't working out their costs properly they would sell for 6 months then disappear I knew their buy price as my best mate was the sole importer for a lot of the items.
23,844
72,808
Ummmm.. mine is the 2.3 :)
Silver-Fox
9,287
29,287
Cheltenham Spa
Rapido
im a not so newbie
The question is who is making and supplying Fiat then.
As Fiat certainly don’t make their own 🤔
Silver-Fox
9,287
29,287
Cheltenham Spa
Rapido
im a not so newbie
Don't know but they will probably be made to a higher spec.
Gates are fitted as oe to lots of main manufacturers according to my spanner monkey mate 😊
Can’t for the life of me remember the other main manufacturer of the belts.
53,764
151,286
It's Gates that workshops have been having problems with, my independent always used them until they started having problems.
PP Bear
7,853
29,017
Kent, UK
Auto Trail Dakota SE
Well worth spending the cash.
23,844
72,808
Canna speak for Fiat but Honda OEM parts are made down to a price..
For instance
The OEM shock fitted to most Honda bikes is pared right down and often need a rebuild by 25k miles.. They last twice as long as that once properly built even using cheap parts !
But as said, know nowt about Fiat stuff and I could be spouting irrelevance !
OldAgeTravellers
1,218
1,415
Telford, UK
Since 1970
Mine is being done today March 2024 estimated price of £1,062 but cheaper than last time . Can't remember which belt make he said but he said they were made on the same production line as Fiat? about the same price as quoted by others but the only one who could do it in a reasonable time. One Commercial Garage said first space available in 6 months!
