Ducato air inlet gets water in when raining (4 Viewers)
May 11, 2023
257
384
Globecar Summit 540
Hi All
Below is a pic after overnight rain. Rain clearly gets in via the bonnet inlet. Does this happen to others, and what is that water running down into? And is it anything to worry about?
Oct 28, 2022
604
1,249
Rapido
Used to happen to my last MH, which looks exactly like yours.
I just added into my first works, to soak up the water with some kitchen roll prior to departure. As i was checking other oils and lubricants anyway.
Rightly or wrongly, i worried about excess water been sucked into the engine?
Dec 6, 2011
12,201
27,282
South Wales
Coach built Adria
Which upper part do you mean?
The grill at the top inside supplies air to the interior via the pollen filter.
Ours does exactly the same, it drains out the back of the engine compartment. If you follow it down the back you will see.
Just make sure the drain doesn’t get blocked.
Apr 22, 2018
7,249
13,291
Herts.
Adria Coral lowline
That is the air intake for the heater/fan system inside the cab. There is a water outlet just down the tube and the air is taken from the top of the pipe, so what you have is not an issue.
Aug 18, 2014
24,725
144,177
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
gus how does the pollel filter come out please thx
I thought that the top part was the pollen filter but others are saying it is a grille & that the pollen filter is inside?
I
May 11, 2023
257
384
Globecar Summit 540
The part on the bonnet is just a plastic grille with maybe 8mm holes!
Feb 21, 2024
37
133
carado
It happens to mine All the time, I usually sponge out the water before driving off, as I dont really want all that water in there, drained or not! Water also gushes out of the scuttle onto the engine. I have built a dam system around the scuttle out of sticks like $hit & quality silicone, cut off the flap on the end of the scuttle drainage pipe that regularly blocks up the scuttle drainage system (by collecting debris) & causes flooding over the engine & bought one of these for when the van is stationary:
External Zip Turn Down Silver Thermal Screen Cover for Fiat Ducato Peugeot Boxer Citroen Relay X250/290 from 2006-2024 Campervan Motorhome Cab Insulation Blind https://www.amazon.co.uk/dp/B0BB83DRM6?tag=mhf04-21 expensive but good quality.
:envy::envy:
Jul 13, 2022
806
2,948
Tarragona, Spain
Adria Twin
The pollen filter is behind the drop down glove box type thing in the center of the cab (or cup holder). A fex torx bolts and its out. Bit fiddly
You mean somewhere here?
If it's there, I understand now why after service in Fiat Professional there was one of those torc bolts in the cupholder and, after dismantling it I found that they had broken a plastic bit there:mad:
Oct 29, 2021
1,123
7,195
Chesterfield, UK
autocruise Rhythm
Most of my life in one form or another
There's a oneway drain at the back of the box. If worried , make sure there are no leaves or crap blocking it .
Checked mine last week and was surprised what came out.
Apr 20, 2022
729
1,414
Brighouse, UK
Autoquest 155 2016
Since 2020
Yes. Behind there.
Feb 19, 2020
1,576
1,823
North Ayrshire
Adria Matrix 670SC
Yes, mine is the same. The water runs out down the back of it. Terrible design, I don't know why they couldn't take air in via the front grill.
Sep 17, 2017
6,223
11,856
Birmingham, UK
A-Class
It's fine. It's designed to cope with water. If you're driving along the motorway in heavy rain, it'd inhale a lot more than that.
