Ducato 2.3 1.8 2020 globecar (1 Viewer)
Buzcan
5
Globecar
Hello , first trip this year ,
Camper started to run like a pig , no warning lights , loss of power under load , managed to get to Glastonbury from Shropshire.
Checked on line for perhaps some ideas , the only thing I've found is about winter and summer diesel , the van filled up in July , used a quarter tank , and topped up on the way ,
Jan 1, 2014
576
1,348
France
Pilote G691 LCE
Since 1974
The difference between Summer and Winter diesel is for the winter version there is an addition of a component that stops (or delays) what is known as waxing which is the thickening when freezing.
Mixing the two should cause no problem unless in real sub zero temperatures, I'd guess you need to look elsewhere for your problems.
Perhaps first look at the actual fuel filter for partial blockage.
What model and year of base vehicle would be a help. Just noticed you say that in the header!
B
Buzcan
5
Globecar
Ducato 2020 reg , 2.3 1.8 power , had no problems until now , only used for a short trip since July , around 59 miles all ok , then this trip started problem , thought it may clear , however after 140 miles challenging drive , when at lower speed , now on campsite
Feb 22, 2011
10,021
20,784
Newcastle under Lyme
Hymer B544 A Class
Since 2015
Might be worth checking the air filter housing for mice nests.
Do you have any dash warning lights on ?
After that I think you'd need a reader to check for fault codes.
The campsite may know of a local mobile mechanic ?
B
Buzcan
5
Globecar
Thankyou , no mice , no codes , when start up all ok on dash
Dec 12, 2010
5,481
22,181
Cumbria
since 2011
I'd be looking around the turbo and associated pipework, possibly a stuck waste gate or jammed up nozzle vanes or a split vacuum pipe/defective solenoid to the turbo ?
Feb 22, 2011
10,021
20,784
Hymer B544 A Class
Since 2015
You've used all your free posts now but the 20 quid to become a full member will be well spent for the useful advice you will receive đź‘Ť
