Dometic RMD8505 control panel removal (1 Viewer)
Apr 20, 2017
139
81
Wirksworth, Derbyshire
Adria Twin Supreme
Since 2006
I have a problem that seems to be quite common in that my Dometic fridge won't power off. As its 12v supply is routed through the main services control panel (Adria Matrix Access 2016), I have to switch this off entirely to prevent the fridge re-starting. I've tried the other fixes suggested in this forum.
I would like to check out the control panel, i.e. check for loose cables, debris, corrosion, but can't work out how to remove it. There seems to be a lot of screws underneath it, and a couple above, but which ones are holding the panel in? I don't want to unscrew something that I later can't re-attach for some reason.
Apr 10, 2024
Niesmann
I currently have the same problem as you describe..........how did you fix yours?
Regards
Henrik
Mar 21, 2021
Ducato van conversio
My dometic fridge rmd8555 is doing the same thing , do i need a new front control panel
Feb 17, 2012
802
7,244
merseyside
Murvi Pimento
Since 2015
Mine was doing the same last year. It didn’t turn off even when I pulled the fuse! I changed the control panel on mine. Mine just had tabs to push in to get it out
haganap
12,775
26,680
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
easy to get out. From memory, either tabs or two screws, follow the line of it. They definitely come out reasonably easy, look upwards in the freezer compartment.
Bustup15
1,492
3,735
Durham
Dethleffs I 7820-2
New to motorhomes 2019
I fitted a toggle switch to the grille above the oven to isolate the power supply to fridge.
