Our awning gets a little condensation on it from the fridge I reckon the fan I fitted does blast out the heat good for drying towels!
When I next visit I will try to remember to take a picture.@Pausim, if you get a moment can you post a picture of the roof vent used to vent the FF? I had never notice that before on a compactline.
Picture as requested.I never realised that we were lucky so to speak in having the FF on the nearside of the van. That's the opposite side to the hab door and awning. @Pausim, if you get a moment can you post a picture of the roof vent used to vent the FF? I had never notice that before on a compactline.
I put it on the back wall about half way down held on with Blue Tack but it needs moving as the controller reports the fridge is at 7 deg but I've had stuff starting to freeze by the door catch. I'm going to extend the wires and fit it under a shelf towards the front.Lenny, I think you have the internal Fridge fan also?, Where did you fit the thermister for that, I was thinking ideally half way down the right hand side of the fridge, is some sort of white trunking to hide the wires.
Also setting the inkbird to turn on above 5/6 degrees, but I guess its trial and error to get the sweet spot, so the fans are not on all the time.
LES
From what I have seen the cooling is much better with a roof vent, downside is you have to take the fridge out to service it. Unless you have managed to clean the chimney just from the lower vent.Picture as requested.
As an interim measure, remove the vent covers as this will improve air flow.
Ian
That's another thing you need to get sorted that is poor installation it should be room sealed and there should be no draughts.wind strong enough to blow cold air around the edges of the fridge/freezer into the vehicle.
Disaster.And more seriously, the beer is not cold and the wine is not cold!
