Dometic Fridge Frame Heater (2 Viewers)
Jul 4, 2021
32
21
Bristol, UK
Hymer B614SL
since 2020
Hi,
Does anyone know if the frame heater on a Dometic 3 way fridge (RMT 7655 to exact) uses the leisure batteries or vehicle battery for power.
I’m hoping leisure but just want to check.
Thanks.
Dec 2, 2019
4,639
10,340
South Lincolnshire
Rapido 7065+
Broken most bits now
What do you mean by "frame heater" ?, if you mean the 12v heating element, then that is powered by the vehicle battery when the engine is running and in some f/f's it can be via solar.
The frame heater heats the door frame around the upper freezer compartment to reduce condensation which can drip into the display PCB and fry it
bigtwin
5,658
10,875
Derby
Concorde
Since 2006
It must be the leisure battery, otherwise it wouldn’t be available when you need it. However, I can’t say that definitively.
Ian
Apr 9, 2024
132
305
Timberland Endeavour
Well that's a couple of confusing answers, I didn't comment because I'm not sure....
Cheers, Dave
Jun 10, 2018
12
14
The frame heater is automatically on when on 240v or on 12v (engine running) as it knows you have power to spare while a power supply is active. When you are on gas you need to manually turn it on with the button and then it will be running on the leisure battery
Apr 9, 2024
132
305
And it transpires that they were both correct. Why did you find them confusing?
Ian
I thought the fridge on 12v was only when the engine is running and therefore powered by the engine battery, so I am wrong? If so, today's been another learning day!
Cheers, Dave.
ps by the way @TwoonTour also said the same....
bigtwin
5,658
10,875
Derby
Concorde
Since 2006
Cheers, Dave.
You are referring to the 12V heating element. The question was asking about the supply for the Frame Heater.
Ian
Jun 10, 2018
12
14
99% of fridges run off the leisure when the engine is running, when engine is started the D+ (alternator live or simulated D+ on smart alternators) triggers a relay which lets the 12v (leisure) reach the elements in the fridge. Yes the charge is coming from the alternator but the fridge itself is nearly always on the leisure battery circuit
Oct 10, 2018
2,183
1,250
Bracklesham Bay, West Sussex
PVC
The leisure battery is used to power the fridge control electronics (and , in the case of a Dometic RMT7655 , the frame heater) with the starter battery , when the engine is running , used to power the fridge 12v heater element.
Cheers, Dave.
Apr 9, 2024
132
305
Ian
Like I said -a learning day, I've never even heard of a frame heater until now.
Goodnight
Dave
a900ss
Jul 4, 2021
32
21
Bristol, UK
Hymer B614SL
since 2020
Perfect. Thanks.
Lenny HB
55,901
163,139
On the coast in West Sussex
Carthago Compactline
The OP's van is a Hymer so the fridge will run from the leisure battery when switched to 12v so the frame heater will run from the leisure battery.
There is a changeover relay in the EBL so emwhen the engine is running g the fridge runs from the starter battery and when the
engine is not running the fridge runs from the leisure battery.
a900ss
Jul 4, 2021
32
21
Bristol, UK
Hymer B614SL
since 2020
Thanks.
