SorryNever had to lubricate, lick works perfectly fine
the police said the same to us, about adding bollards outside the works premises when a spate of raids were going on, "that really tells thieves that there is something in there worth stealing/ram raiding".that fitting it lets everyone know you are not in the van
You could also argue that if you were parked with other motorhomes that thieves would choose the ones without additional locks.I have a similar Milenco Frame lock, still in its box from the day it arrived!
A "wised up Funster" pointed out to me at a rally, that fitting it lets everyone know you are not in the van, as it can only be opened/closed from outside. Hence why its never been fitted, I dont want any van doors crow barred to enable any thief to enter. The Growler Alarm should clear them out pretty quickly if they are not deaf, then they will be by exiting.
LES
Yea I know, you were "the wise funster" that advised me after I had bought it!I fitted one to our van but never put it into the locked position, so does a potential thief think are we in the van or not when it's in the unlocked position ?
I am a loner, no likes me, when I park up, everyone moves!.You could also argue that if you were parked with other motorhomes that thieves would choose the ones without additional locks.
if fitted properly in a metre of concrete they should be immovable.about adding bollards outside the works premises when a spate of raids were going on, "that really tells thieves that there is something in there worth stealing/ram raiding".
Marquis - the company that keeps on giving…….Fiamma safe security door lock .
Fitted on purchase of new van from marquis, from start it began to peel, brought it to their attention but it was never sorted.
Now it looks eye sore and they say:
It only has 6 mth warrantee so basically tough?
Sooo, apparently they all go like this, or do they?
Seriously? I is enough for me won’t be having another fittedHad it happen on 3 I have fitted now, the coating don't last much longer than a couple of years
That's why you see attics with the sides open when parked up on laybys.the police said the same to us, about adding bollards outside the works premises when a spate of raids were going on, "that really tells thieves that there is something in there worth stealing/ram raiding".
I said by that rational, then I should leave the doors wide open should I.
Let them move on to a van without the locks
yes on our Chausson did the same
seems to be a common thing, the galvanised alluminium reacts with the paint causing some blistering, last longer than others, but did seem common when I looked into it.
Some said sand it and apply correct etching primer/paint but I wasnt too bothered at the time
Looks more like poorly applied powder coating to me. Anything I have have ever owned from Fiamma has been of very poor quality.yes on our Chausson did the same
LES
Yup mines the same.Total crap.Fiamma safe security door lock .
Get yourself an old ambulance we soon shift em.Lucky you, can you pass on any tips
