- Sep 6, 2021
- 75
- 76
- hymer b class mct
I anticipate a couple of years!Shouldn't have to wait long.![]()
The EBL271 is one of those that has Pin 2 of the 3-way solar connector wired to the starter battery. Not all EBLs have this, which may be why Votronic don't use it in their wiring scheme. So yes, just connect the existing wiring to the new Votronic controller. No need to bodge a wire onto the rear terminals, or run a wire direct to the starter battery.So, my latest thinking is now to buy the Votronic MPP 250, and use the existing cable/connection to the EBL 271. Presumably the connection at the EBL will be OK as it was working OK with the Schaudt LR1218. I just need to adapt the cable ends and make sure they are connected to the right terminals on the MPP 250. The Votronic wiring diagram shows only 2 connections to the EBL, and the starter battery + going separately direct to the battery. Am I right in thinking that if I use the existing cable to the EBL and connect the wire that was previously connected to "Starter Plus" on the LR1218 to the Starter + on the MPP 250 it should all work fine? Which saves me running a separate wire to the starter battery.
Great to have it confirmed. Thanks to everyone for their contributions. I just have to find a Votronic at a sensible price on a reasonable delivery time. So far, so bad.The EBL271 is one of those that has Pin 2 of the 3-way solar connector wired to the starter battery. Not all EBLs have this, which may be why Votronic don't use it in their wiring scheme. So yes, just connect the existing wiring to the new Votronic controller. No need to bodge a wire onto the rear terminals, or run a wire direct to the starter battery.
I have the Votronic Duo350 and it connects and integrates with my EBL showing the charge state information on my DT220 ...it came with all the connectors in the box to plug straight in to my EBL..It is expensive. That Votronic is the other one I'm looking at. Apparently it comes with the right cable to connect to the EBL that I have.
At least 4 hours, that is the default on Votronic & Victron solar regulators. Older EBL's were 8 hours latest ones 16 hours., why they changed it to 16 hours I haven't a clue but seems like overkill.Hi Lenny
So if my control panel displays fully charged batteries, they are possibly only 80% ? how long is the absorption charge then ? either way we have plenty of power for what we need. The Exides are the business.
