- Nov 19, 2023
- 77
- 38
- VW lt35 1995
If I get rid of my 3 way fridge ( which doesn't work on gas anyway)
Can I, internally, cover up the vents?
I'm not sure which would be better. A fridge isn't that power hungry, so it won't be giving you much heat. Probably only 20 watts average. But if the back was vented against the cold outside, it wouldn't have to work as hard. So you'd probably reduce your power consumption.There is a thread somewhere about a self build that has fanned the hot air from behind the compressor fridge to his van internal during the colder weather.
Yes, my plan is to get a compressor fridgeDo i assume you will fit a compresser fridge to replace
In theory you can but your new fridge will benifit from good cool ventilation to its compresor
Just what I was thinking reading this.Mine are completely blanked off, let's face it you don't put a hole in your kitchen wall for the fridge at home.
I do take both covers off in Spain though.
Thanks, I'm only using my van at the weekend at the moment so I'm in no rush to get a new fridge but it so windyMine are completely blanked off, let's face it you don't put a hole in your kitchen wall for the fridge at home.
No you don’t but you have ventilation all round and at the topMine are completely blanked off, let's face it you don't put a hole in your kitchen wall for the fridge at home.
If you look at any Dometic fitting instructions you should have through ventilation for compressor fridgeJust what I was thinking reading this.
We don't have fans to ventilate domestic fridges
I just can't imagine that, the small amount of heat collected from the evaporator will dissapate into the air and cabinet wood. The compressor is cooled by the condenser fan but also the cold vapour returning. The fan always runs with the compressor.You compressor fridge will be getting too hot fan will be cutting in too often
From experience from what I have seen several times the heat is stuck within the back of the cabinet the fridge walls are not very well insulated and it warms the fridge wall and is counter productiveI just can't imagine that, the small amount of heat collected from the evaporator will dissapate into the air and cabinet wood. The compressor is cooled by the condenser fan but also the cold vapour returning. The fan always runs with the compressor.
It's good that the condenser gets warm, if it's cold the head pressure is too low (you need a decent pressure to condense the refrigerant back to a liquid) some commercial systems switch the condenser fan off and on via a pressure switch in winter to keep the head pressure up.
For safety reasons, I thought that the back of the fridge area was supposed to be completely sealed from the habitation area!There is a thread somewhere about a self build that has fanned the hot air from behind the compressor fridge to his van internal during the colder weather.
That’s gas fridges perfectly ok for compressorFor safety reasons, I thought that the back of the fridge area was supposed to be completely sealed from the habitation area!
That's what I thought after I had posted but I thought I would leave it up there for clarification incase it also involved the coolant agent in the pipes?That’s gas fridges perfectly ok for compressor
For clarity you dont need external vents for a compressor fridge , you should have ventilation be it internal or extenalOur Vantage doesn’t have any vents for our compressor fridge and it works fine.
I have 2 freezers & a fridge . This summer I had to have fans blowing on the condensers to assist evaporator cooling & stop them running 20 hours/day due to the heat.We don't have fans to ventilate domestic fridges
I am planning on swapping my Thetford 3 way for the eqivilent compressor model and asked the Thetford engineer (who just happened to be on a stand at NEC show) the exact same question. His answer was OK to block off the vents with Selotex or similar and definitely not to mess with the new fridge air flow.Mine are completely blanked off, let's face it you don't put a hole in your kitchen wall for the fridge at home.
Hi, is that going to be built in or free standingI am planning on swapping my Thetford 3 way for the eqivilent compressor model and asked the Thetford engineer (who just happened to be on a stand at NEC show) the exact same question. His answer was OK to block off the vents with Selotex or similar and definitely not to mess with the new fridge air flow.
I'd block both vents for now Lyn and see how the new fridge runs once it's installed.Hi, is that going to be built in or free standing
