I haven’t re visited this tread, and some attachments can’t see. If I understand correctly you are after a 48v DC system, coupled with AC grid inverter. The multiplus is been bench tested and lots of R&D done in collaboration with Fronius. In the Fronius you select MG micro grid, and will load all necessary settings to work with the multiplus 2. It works with other inverters but not as nice as with Fronius. Either way you will need a GX hub, ess assistant, and a victron smart meter to see the PV inverter in the victron app.
Then you can have your LFP coupled to the multiplus.
