Differential dpf sensor,Twin EGR model.2017 (1 Viewer)
Dec 6, 2011
11,773
25,952
South Wales
Coach built Adria
the set up on our 2012 is that of air pipes, one at the front and one at the rear of the DPF ( those being the points of differential pressures ) that go to the DPF sensor fitted on the chassis near the offside front wheel which houses a diaphragm and some contacts to 2 wires that go to the ecu box of tricks.
the1andonly
Jan 27, 2018
2,729
2,189
Northampton
Rapido & Bongone
Phill D thanks for reply i spent many a time searching for my sensor after your description a couple years ago the twin egr sensor is high up on the firewall. the DPF is mounted high up behind the engine, i was hoping some poor sod has already been there with pictures to prove it.:LOL:
are the connections anywhere near the O2 sensors?
Dec 6, 2011
11,773
25,952
South Wales
Coach built Adria
Mine as you know is not twin egr.
Do I may not be able to help, but I am happy to crawl under my van and phot the sensor location and the dpf take off tubes.
the1andonly
Jan 27, 2018
2,729
2,189
Northampton
Rapido & Bongone
If it aint too hard that would be absolutely supurb. the take of positions in relation to O2 sensors would be usefull. Thanks
Dec 6, 2011
11,773
25,952
South Wales
Coach built Adria
It ain’t stopped rising yet so there is going to be a delay in me crawling under the van 🙄
Dec 6, 2011
11,773
25,952
South Wales
Coach built Adria
pas de problemo fy ffrind
Ok I managed to get some photos in between rain showers but to get better ones I will need to raise the front end. See what you make of these and if they help any.
The rear air pipe on dpf
The front air pipe in yellow and one of the sensor locations in blue.
The rear sensor blue arrow
The dpf differential sensor orange arrow. The 2 rubber pipes are from the front and rear air pipes and the wiring goes to the harness.
The white sleeved wiring from the sensors in the dpf go into the harness
the1andonly
Jan 27, 2018
2,729
2,189
Northampton
Rapido & Bongone
Phill D thanks a lot. i couldn't make out the Differential sensor but doesn't mater as mine is in a totally different place.
The blue bit is centre of cab where the Dymax and Turbo solenoid are mounted
