TUT
After a year in storage how’s best to start a Fiat Ducati 2.3, considering the Oil which was new just before storage has drained to the bottom of the engine?
Just edited this post, a pump is not a pump without an outlet!The pump generates zero pressure. Pressure is generated by restriction of its outlet by the interface between oil drillings and bearings. Provided that pump throughput exceeds the ability of the bearings to leak oil then pressure is generated. As bearing clearances increase due to wear oil dispersal from the bearings increases and less restriction is offered to the pump. Once the pump excess flow is used up the pressure will drop.
You certainly can. If there's no restriction on the outlet it simply moves the liquid. Or in simple terms if you have a pipe on the inlet full of liquid and a pipe with a pressure gauge teed into it on the outlet do you think you'd read pressure when the pump was started?What? With respect you cannot have zero pressure on the outlet of a pump, I’m sure that is a typo.
If the pump moves the liquid from a-b there is force involved Which could be measured doesn’t matter how big the outlet isYou certainly can. If there's no restriction on the outlet it simply moves the liquid. Or in simple terms if you have a pipe on the inlet full of liquid and a pipe with a pressure gauge teed into it on the outlet do you think you'd read pressure when the pump was started?
If you connect the pressure gauge to the outlet with nowhere for the liquid to go other than against the gauge you'll read whatever pressure the pump is capable of generating.
Of course. No pressure is involved though. Power is input to the pump and, assuming 100% pump efficiency, is available to be taken from the liquid as it leaves the outlet. Don't take any power, no pressure is developed. Some power is absorbed by pump and pipe friction and pump and motor inefficiencies but pressure isn't developed until something tries to slow the flow out of the pump.If the pump moves the liquid from a-b there is force involved Which could be measured doesn’t matter how big the outlet is
Agreed, when fluid pushes against something there is pressureOf course. No pressure is involved though. Power is input to the pump and, assuming 100% pump efficiency, is available to be taken from the liquid as it leaves the outlet. Don't take any power, no pressure is developed. Some power is absorbed by pump and pipe friction and pump and motor inefficiencies but pressure isn't developed until something tries to slow the flow out of the pump.
Like it, it is a nice reference, the forces are high for that to be useful but I suspect that the forces that can be generated within a braking system are fare less than that required to compress a liquid.Here's the original patent with drawings. Very interesting!
US2563194A - Liquid spring resilient unit - Google Patents
patents.google.com
You are, of course, CORRECT! Sorry had a senior moment, as I said, I am VERY oldA liquid of any sort is effectively non-compressible. The reason brakes become spongy when the fluid is contaminated with water is that the mixture has a much lower boiling point than pure brake fluid. It's the vapour produced by the mixture when heated by the pads / shoes that makes the pedal go soft. When cold the brakes will operate normally with only water as an hydraulic fluid.
I'm glad you included the question marks. After a year in storage, anything could have made its home under the bonnet so, at least, give that a quick check.Turn the ignition key??
PM me your address, I think you need my specs more than me, but thanks for the complement ?You certainly don't look it ?.
