What is it called?The PC is now usable but I think I have found the problem. I have one program that will not uninstall.
Have had enough for today.What is it called?
The problem program appears to be "Cyberlink Madia Suite".What is it called?
At least that is the one I cannot uninstall. Trying to opens multiple windows quicker than I can close them with Task Manager. I don't know if that is what is making loading etc so slow.
Yes. Unfortunately I already have CL Cleaner. It is a good disc cleaner and. Reasonable, rather than brilliant, Registry cleaner.A quick search came up with this.
CL CLeaner. From Cyberlink themselves.
http://www.cyberlink.com/support/product-faq-content.do?id=16027&prodId=186
I am not on about the registry/system cleaner. The CLCleaner I linked to is specifically for cleaning up CyberLink install problems.Yes. Unfortunately I already have CL Cleaner. It is a good disc cleaner and. Reasonable, rather than brilliant, Registry cleaner.
However, it doesn't help.![]()
Thanks.I am not on about the registry/system cleaner. The CLCleaner I linked to is specifically for cleaning up CyberLink install problems.
I linked to this page because I don't know which version of the software you have, and each version has it's own CLCleaner version.
Thanks.
After my previous post I realised I was wrong and followed your link. However, even their own cleaner cannot seem to remove it in this case. Seems as though the initial attempt to uninstall has corrupted a file within the program that sends everything off track.
As I just tend to use the PC for letters and for update of maps on my Sat Nav l will live with the improved, although still slow, performance. I use iPad for most other things now.
Thanks to everyone who had tried to help. If I eventually find an answer I will post it.
