Delaminated roof (1 Viewer)
Mar 31, 2015
252
263
WORCESTER
Autotrail 660 merc
SINCE 2012
got a friend with escape 664. 2010
Roof seams all lose, delaminated I presume.
Problem is the dealer he bought it off, ever time it goes in for work it comes out with another prolem .
Thay say the roof has to come off so he's dreading it going in.
But he's got another two and half years warranty, but worried it mite come out leaking.
Will it hurt left alone.
Andy
MikeD
3,936
3,697
London
IH PVC
Since 2012
I would have thought a "roof off" repair would be a factory visit type of job.
I consider it will definitely hurt if left alone.
It would be unsellable unless repaired.
We feel for him - our Autotrail started leaking after three years.
Scattycat
920
1,262
Mayenne, France
Rapido
Since 2010
Andy
It might well be a floating roof in as much as the gpr/ fiberglass roof sits on the inner roof but is not fixed to it, much like the Rapido roof construction
If this is the case then there often is an amount of play between the 2 structures and especially when in very hot climates it will show some distortion.
MikeD
3,936
3,697
London
IH PVC
Since 2012
And same for Autotrail (y)
Minxy
32,683
66,689
E Yorks
Carthago Compactline
I suggest your friend gets in touch with Swift direct and asks the question as it's not uncommon for some coachbuilt roofs to do this as the outer material can shrink/expand depending on the temperature, sometimes they can look really bad but in reality they're sometimes meant to do it! We had a 2001 Swift and it did this.
Oct 14, 2007
4,002
6,264
Rochester
Auto-Trail Mohawk
16 fun filled years
I thought the back of our Autotrail Mohawk had delaminated as iwas going in and out when washing it, made enquiries and it's supposed to be like that, it does seem strange.
LOOSE WHEEL
Mar 31, 2015
252
263
WORCESTER
Autotrail 660 merc
SINCE 2012
Thanks for all info this will help put is mind at rest if it is a floating roof.
Will get him to ring swift.
As for dealer, big name in Tewksbury the less said the better.
Andy
Minxy
32,683
66,689
E Yorks
If he keeps getting problems with the same dealer why doesn't he take it to a different dealer.
Unfortunately other dealers aren't always willing to sort out warranty issues if you didn't buy the MH from them.
