Degrees of inclination.
Maspalomas, Spain
Giottiline Toscan 74
What do you all think is an acceptable amount of inclination before using ramps? Where we are parked right now, we have 2.2 degrees forward and 2.2 degrees to the right according to my bubble level on the phone but we don't notice it inside the van. I have read that the fridges, when using gas, don't work so well if not completely level. Any thoughts?
New Zealand
Mutsubis fuso/canter
5 years
I have a compressor fridge, so no issues there.
I sleep according to direction of "fall" both north/ south and east / west
As long as my head is higher then my feet... its all good.
I would probably look at leveling if I had to use climbing ropes to get from one end of the motorhome to the other tho. (y)
God's county. Helmsley, North Yorkshire.
IH Tio 630 RL
Since April 1846 but have always camped.
You can measure that accurately with an app? 🤣🤣
Hampshire
Chausson 640 welcome
Since October 2019
Damn that’s accurate 2.2 degrees ? If the cupboard doors dont smack me in the face and the fridge keeps the vodka cold then that’s fine . Personally never had the fridge not work because we had a lean .
Co Durham
Autosleeper Amethyst
Newbie, former van camper and still wild camper
We put a bottle of wine on the counter if it rolls off before I can catch I get the ramps out......... results are sketchy if we have consumed the first bottle on arrival :oops:
Upvote 1
Elddis Accordo 105
eight years in theory, a newby in practice!!!
We check that the water can drain from the sink. We've got E&P self levellers which we use virtually everywhere because our van sits naturally nose down. They also stop the bounce when you walk about and will keep the van rock steady in the strongest of gales ;)
Hampshire
Since October 2019
On a serious note , if we are staying on a site for a few days then we will take more time to get the level right , swing the chairs around etc . But if touring - no , quick setup
A Class N+B Arto 69GL
Since 2009
Never used levellers. Never had a problem with a fridge in MH, nor boat - which also did not use levellers. :LOL:
Have you lot heard of non-slip mats? Whole roll cheap as chips.
We use sheets of it to line the bottom of cupboards to stop things slipping together and rattling.
EAST ANGLIA
Murvi Morello
Since 1975
I think you will find that Dometic/Thetford fridges are ok up to 3 degrees of tilt
This has always intrigued me because, I have had 2, three way fridges, Electrolux ( I think) (1 in the VeeDub and another in the Murvi) and I've never had the problem of it not working whatever the angle.
I have to admit, I do like my feet slightly higher than my head for sleeping, wherever possible, would that make a difference? 🤔
jumar
Spain
Hymer Tramp
Since 1994
We are slightly inclined to remain on the level 🤭 last nights Aire (Camperstop) prohibited the use of such items...and have worded the rules in a way that cannot be interpreted differently..both in Spanish and English...
Only the wheels should be in contact with the ground, it states....therefore being near perfect and considerate motorhomers, we parked, ate and slept on the Tilt...we slept well, woke fresh, fridge performed as expected at 2.75° incline...nothing rolled off plates or tables or any other surface...and Spain beat Germany...which is partly due to my TV being 2.75°...
EAST ANGLIA
Murvi Morello
Since 1975
Did you turn the van around when they changed ends in the second half or was the goal in the second half?
You can tell I'm really interested in football can't you? 😄
jumar
Spain
Hymer Tramp
Since 1994
Well actually....No...but would consider this in future if my team needed assistance..🤭
jumar
Spain
Hymer Tramp
Since 1994
Just a holiday supporter then, a real supporter would turn their van around in case they needed assistance.
What would happen if the assistant was needed in the last 2 minutes? 😄
OK....I report back later, as my second team is playing tonight...if I can help to secure a victory, I'll be that man...🤔🇪🇦
CAB96
Stockport, UK
T6 Leisuredrive
But what about extra time? Turning the van every 15 minutes :unsure:
And penalties :eek: Do we have to turn it after each one :rofl:
