Patrick and Lesley
can anyone recommend good dealers in the Midlands . I live in Worcester and need dealers that have cheaper motorhomes upto 22 k any suggestions much appreciated.)
It really depends how long you go away for and what you want to take, if you don't take bikes etc then 500kg may be sufficient but if you like 'toys' with you then the sky's the limit!Thanks for your time replying. Is there a minimum payload I should be looking for?
Thank you. I get what your saying. How do I find out the weight of the Motorhome before adding any of my stuff and occupants. Handbook? If a 18 ft Motorhome has a gross weight of 3400 kg that should leave me enough margin to stick a couple of bikes on 2 occupants all weighing in under 140kg + all the other necessaries food, toiletries , clothes etc. ? Thanks again your being most helpful.It really depends how long you go away for and what you want to take, if you don't take bikes etc then 500kg may be sufficient but if you like 'toys' with you then the sky's the limit!
It's not the gross weight (known as the MAM/MTPLM - ie the maximum weight shown on the vehicle plate which is the first weight shown on it) that you need to look for but the weight of the MH with nothing in to compare to the gross weight as the difference between them is how much payload is left which you can theoretically 'use', so long as doing so doesn't take you over either of the individual axle weights maximums.Thank you. I get what your saying. How do I find out the weight of the Motorhome before adding any of my stuff and occupants. Handbook? If a 18 ft Motorhome has a gross weight of 3400 kg that should leave me enough margin to stick a couple of bikes on 2 occupants all weighing in under 140kg + all the other necessaries food, toiletries , clothes etc. ? Thanks again your being most helpful.
How did you get on today?Thank you again for taking the time to explain it. Payload It’s something I wouldn’t have given a thought to. Visiting a dealership today I feel better prepared.
How did you get on today? .
Unfortunately they were closed. I automatically thought they would be open on a Sunday. Hopefully we will get there later this week early next.
