No one letting on then?So what do you do with these test things, never having had a test I am baffled by it all, do you just stiCk them up your nose and send them back or what?
Yes would be the answer to your original questionNo one letting on then?
Ours were tonsils and nose then snap off the end of the stick in the tube and post off. Posted Tuesday afternoon just got back the result this morning.No one letting on then?
someone definitely posted that they had.Just on a side to the original post, has anyone never done the 2 day test even though you have bought one just so you could put the reference number on the locater form .
Welcome to my world.Just been on Gov.uk site to see now much Day2 LFT tests are now for travel into UK from the 24th.
Surprise surprise no cheap prices and usual ambiguity. Oh now it's crashed.!!!!!???
Just wondering if you found this company OK.£12 per test we are going to try these people for next week.
Home
Simply Test Me is no longer trading. Thankfully, the world has reopened and we are able to get back to 'normal' life. We thank you for your support over the recent difficult years, and hope we managed to make your life that little bit simpler with our testing solutions.www.simplytestme.co.uk
We just ordered ours from these....code back in 5 mins.Just wondering if you found this company OK.
Yes no problem.Just wondering if you found this company OK.
I do believe this option actually works.I will try entering my old test numbers.BUSBY.
I can confirm this does work several times although the format has changed since the day 2 tests came in so you cannot use an outbound fit 2 fly test as the code is different but the test and the certificate are identical.I do believe this option actually works.
Yep, we used them worked fine, did our tests yesterday got an email confirming we had uploaded our results then a few hours later another email saying our results had been accepted.Just wondering if you found this company OK.
