That's interesting (and perfectly logicalIn constant current mode, charger does not use the battery 'open circuit rest voltage' as an indication of the state of charge of the battery. The manufacturer has determined from extensive measurements that there is another method to find out when the battery is 80% charged.
When a fixed current is put into a flat battery, the terminal voltage will be less than 14.4 volts. The measured terminal voltage will depend on the state of charge of the battery. For example, if that battery is 80% charged, the terminal voltage at the fixed current will be 14.4 volts. It is safe to push out the fixed maximum current into a flat battery, until the voltage rises to 14.4 volts. At that point, the battery is 80% charged.
Another way of looking at this is, the charger is trying to apply 14.4 volts to a flat battery, but the charger does not have the current capability to make the voltage up to 14.4 volts, so it struggles along, applying as much current as it can, until the voltage finally reaches 14.4 volts.
