A little more progress over the last few nights. It’s starting to resemble a MH again
Fitting the walls back with some clamping action.
Following closely by the middle and final wall section.
once the walls had dried it was then onto fixing the floor down. I used a mixture of five minute wood glue and nails to hold the ply in place. The glue expands to fill some gaps. Before I put the floor ply down I had filled the voids with expanding foam. I did two layers to just under the wood height. Just before the final fit of the floor I added the last layer of foam. This with the glue has formed a strong bond.
The final finish looks pretty good and I’m pleased on how it turned out.
Need to jump onto the locker door surround now while the weather is holding. I will then fit new flooring, rejoin the floor to the chassis and wallpaper the walls.
