I retro fitted a Kenwood DAB stereo to my V- Line 600, and had a sticky windscreen mounted aerial fitted. No problems with reception. Original aerial now not even plugged in!
Sensible advice Eddie. I have a Hymer S650 and spent loads on aerials when I fitted a DAB unit and none of them worked effectively. “A class syndrome“ I guess as no real ground plain. Easy solution now adopted - Unlimited data on my phone and stream through the head unit using either direct USB to the head or Bluetooth (both work reliably). Just used the same approach in a hire car with a cheap vent mount to hold the phone in view driving from Zurich to Davos and back for work and it worked faultlessly for Radio and Nav. Simple cost effective solution!Genuinely I spent a fortune on the last motorhome, buying and trying all sorts of DAB aerials, and fitted them in a variety of ways
In the end, I got hold of one that was pretty good, I mounted it to a metal plate which I when I fitted it as close to the middle of the roof as I could, I connected directly to the chassis with a 6mm square wire and used a signal booster to amplify the input signal into a plus £2k head unit
It worked, most of the time, but I had spent hours, literally hours on it and I could be bothered listening to my staff arguing with customers who couldn't undertstand that their new £150 ('ish) aerial could cost hundreds of pound to install depending on the motorhome and "No, Sir, sorry it still doesn't 100% guarantee you reception.
So we decided to simply say "No" we don't know of one that will 100% guarantee you reception and as I couldn't be bothered to go through all that again when we got our new camper last year, I didn't so I listen to the radio on the internet and rarely have any issues what so ever, nor do I get my wife asking "Why's the radio gone off?
Bliss
I seriously doubt it , i suffer the same thing regularly in different vehicles . Unless all those aerials are duff , my personally thought is transmission system is not fit for purpose . Fine in a fixed location , but mobile , frankly you're better off with long wave .So my suspicion is the aerial in the Ducato isn't up to the mark.
When they first introduced DAB it wasn't very good now days I find the DAB reception far better than FM but I suppose it depends where in the country you are.Isn’t the issue with DAB that the transmissions are variable and mostly patchy (not enough transmitters) and the frequencies cannot hold all the info all the time so it doesn’t matter how much you spend on aerials and receivers you will still get crap reception a lot of the time.
Might as well throw your money in the bin they are pretty useless.Put one of these between the aerial and radio
Amazon product ASIN B09FQFGMY5
Sorry don't know, its a small whip aerial on the roof which is aluminium so doesn't need a seperate ground plane. Same aerial is used for FM and TV, TV reception is very good, they fit an amp for tv somewhere I've yet to find it.
Your roof will have the GRP sheet on top so you need to connect the aerial earth to the inside of the roof. Mine has a big plastic cover in a top locker on the inside of the roof which also houses the GPS receiver for satnav. I just tried to get the cover off to have a look for but it was really tight and I didn't want to force it.Cheers, never gave it a thought that the outer layer of the roof is aluminium. Just need to find a convenient spot to fit it and gain easy access inside. Cheers yet again Lenny.
Agreed. I tried those in both my Motorhome and my Jeep and they were both useless.Might as well throw your money in the bin they are pretty useless.
Thanks for having a look. You wouldnt have volunteered here in Cumbria today its a classic wet day all day and for the rest of the week then back to cold Minus temps! Oh joy!Your roof will have the GRP sheet on top so you need to connect the aerial earth to the inside of the roof. Mine has a big plastic cover in a top locker on the inside of the roof which also houses the GPS receiver for satnav. I just tried to get the cover off to have a look for but it was really tight and I didn't want to force it.
My reply is to the original post... Sorry to have upset you!Why would I remove the mirror protectors which have a purpose when the wing mirror aerial had already failed and the second aftermarket FM aerial fitted to a wing gave poor reception. The all in one aerial I fitted solved the FM reception as well as the DAB reception which is after all the core of this post.
Do you have mirror protectors? Try without....
The best quality I could find on the DAB list was for BBC Radio3 at 160-192 kbps which is probably still a bit of an insult to many music lovers ears. Bear in mind that CDs have a bitrate of 1411 kbps.interesting article here: Why DAB is so poor
