Cycle rack lighting board (4 Viewers)
Welsh girl
3,658
3,036
Globecar
Since 2004
I have a globe car, transit base and after having a cycle rack fitted I noticed that the wheels of the cycle will cover the lights on the van.
I have bought a trailer board to fix to the rack but can I wire it myself and how is it done?
The local garage wants to charge £120 He said its 1 and a half hours work.
Is this feasible please?
Welsh girl
Welsh girl
3,658
3,036
Globecar
Since 2004
Not sure what's meant by Canbus
Mr Chrysalis
2,367
318,094
Lincolnshire
Rapido 890F A Class
Since 2016, caravans before that, folding Caravan, tents before that
It would be very easy if you had a tow bar, or tow bar electrics, I assume that is not the case?
£120 doesn’t sound bad. Here are some prices for fitting tow bar electrics at Halfords - look in the 7 pin electric column. That is essentially what you need ( a plugto plug your trailer board into). Halfords is not the cheapest but your local garage price is better anyway
Prices
Below are indicative prices for tow bar fitting at Halfords Autocentres. Go to tow bar fitting to get an accurate price for your vehicle.
Most popular cars fitted with tow bars Tow bar type Electric kit Total price from
Fixed
Detachable 7 pin 13 pin
Audi Q5 (2015) £301.92 £386.83 £150.48 £201.60 £452.40
Dacia Duster £254.58 £362.50 £124.32 £184.32 £379.14
Ford Kuga £284.50 £411.84 £172.08 £203.04 £456.58
Ford Mondeo £270.61 £418.93 £132.48 £182.72 £403.09
Ford S Max £264.17 £409.48 £132.48 £180.72 £396.65
Kia Sportage (2014) £311.20 £415.96 £205.20 £244.80 £516.40
Land Rover Discovery Sport £426.13 £521.96 £110.16 £87.84 £536.29
Mazda CX5 £235.42 £348.46 £151.92 £203.04 £456.58
Skoda Octavia £215.58 £322.91 £221.04 £237.60 £473.65
Skoda Superb £252.61 £360.14 £221.04 £237.60 £473.65
Vauxhall Astra Sports Tourer VII £281.96 £394.37 £159.12 £162.72 £441.08
VW Passat £252.61 £360.14 £221.04 £237.60 £473.65
*Prices correct at 27th July 2017
Mr Chrysalis
2,367
318,094
Lincolnshire
Rapido 890F A Class
Sorry table did not print!
Apr 12, 2010
4,813
51,833
Bury St Edmunds, West Suffolk
Weinsberg Cara
since 2007
If you use it occasionally you could take the front wheel off and move the bike over.
Canbus is used on most modern vehicles these days and could well take 1.5 hours to wire up.
Phil
Welsh girl
Welsh girl
3,658
3,036
Globecar
Since 2004
I just read up what a can bus is and I do have one.
But taking the wheel off is a good tip
Welsh girl
Welsh girl
3,658
3,036
Globecar
Since 2004
Prices
Tried that but it comes up as not found.
I'll try taking the wheels off first.[/QUOTE]
Apr 11, 2017
1,413
6,814
Earby, Lancashire, UK
Autocruse Select 144
started Oct. 2016
I suggest you reposition you bike so the lights are visible. Turn the bike to face to other way or upside down, i.e. wheels up.
Phil
Minxy
32,667
66,615
E Yorks
Carthago Compactline
... taking the wheel off is a good tip
If you haven't got a quick release front wheel you can easily adapt it make it quicker to do than pratting around with spanners. One benefit is that you can then turn the handlebars 90 degrees so the front forks sit in the bike rail which means it doesn't stick out so much too.
Apr 11, 2017
1,413
6,814
started Oct. 2016
Minx-girl is correct but if you do turn the handlebars at 90 degrees LOOK UP, as the handlebar ends may be a lot closer to the super soft skin of the rear panel of you precious motorhome. Been there, done that.
Phil
Nasher
2,094
7,179
Pontardawe
Pug Boxer
Since 2013
Contact a local tow bar fitting place & ask them how much for the electrics only - it may be cheaper than present quote
Aug 6, 2013
11,955
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Canbus only means a cheap interface box that isn't complicated to wire in - it shouldn't add more than a tenner to non-canbus prices. Do remember to remove any triangles on the trailer lighting board.
Canbus only causes serious expense if the vehicle manufacturers towing conversion is used.
Oct 2, 2008
4,473
7,960
Salopia
Duro 6x6 Overlander
since 1968
If you have a tow bar fitted then there should be a towing electric socket . Then all you do is plug board into that . @Welsh girl also as @Nasher
also if it hasnt
Welsh girl
Welsh girl
3,658
3,036
Globecar
Since 2004
Well We travelled to our rally with the bikes on the rack.
One wheel off as he had quick release on his wheel we took the front wheel off but he had both the rear wheels on the left and I'm concerned that it might be too heavy on the one side.
More experiment needed.
Minxy
32,667
66,615
E Yorks
You could put one of the front wheels between bikes at the 'fork' end and bungy another on the outside, or just turn one bike round and put both front wheels between the bikes, that way you don't have to put them anywhere else.
