Cupboard door handles (1 Viewer)
Jun 1, 2021
35
25
Bursner Nexxo 660
Hello Funsters
Hope this is the right section. I’ve got two cupboard door handles which have failed in the same place. I wonder if I can source the plastic bit without having to buy the whole thing?
The bit wot’s broke is the flexible plastic that sits inside the handle so when you squeeze it the catch releases. Clever but not strong enough clearly.
Any ideas most welcome.
funflair
19,427
30,576
Guisborough
MORELO palace
since 2012
I'm guessing the top end of the photo is the bit that releases the catch and the bottom end is where it pivots, "me being me" I would be trying to repair it as the plastic looks like it has a rectangular area that would accept a small metal plate and a screw.
"me being me" roughly translates as short arms and deep pockets ;)
And to answer your question I think you would have to buy the full handle.
pj650
231
691
Gretna. Dumfriesshire.
Bürstner t740
Motorhoming since 2002
Also being “careful with money “, I managed to repair the handle at the rectangular area using Araldite and a small piece of plastic set into the recess. Still good two years later.
I dread to think how much a new handle would have cost.
Baxters@large
Jun 1, 2021
35
25
Bursner Nexxo 660
Thanks both. Repair an option I guess although very small bonding area so would need some reinforcement as you suggest. As they’ve both broken in exactly the same place I guess they’re a lot of tension there at the fixed point when you squeeze the bar to open the catch. It’s really bad design.
pj650
231
691
Bürstner t740
You’re right, it’s a very poor design. Our two that broke were directly below the kitchen worktop and over time had got bits and pieces eg crumbs inside the handle which made them stiff and uneven to pull, which is why they broke where they did. Once cleaned and repaired they have been no problem. Good luck 🤞
Oct 9, 2017
67
43
Cardiff
20 yrs on and off
I have problem with identical catch on a drawer under the fridge.
The cast internal mechanism has become damaged.
Does anyone know where I could obtain spares?
