CTEK battery charger (1 Viewer)
davejen
1,861
1,235
Preston
Given up travelling
Since 1992
Anyone know where I can get one repaired?
It worked fine till it fell off the shelf- now shows no output when connected.
TIA
Cheers, Dave(y)
bigtwin
5,253
9,968
Derby
Concorde
The shock has probably ruptured an internal fuse. Worth whipping the cover off to check that isn’t the problem.
Ian
Abacist
3,776
10,993
Devon
N & B Arto 88F Tag
since 2013
If its more than a fuse you could try Apuljack engineering in East Breen Somerset if CTEK don't have a returns system for repairs.
glenn2926
3,326
13,619
Gods country
Chausson
newbie hired 3
It might be cheaper and quicker to buy an optimate made by Oxford. I have one on my motorcycle and have used it on the motorhome before. It worked very well. However it is not a fast charging thing. It keeps the battery in good condition by slightly discharging and recharging. Not very expensive. It has lights on it telling you what it is doing.
Jan 19, 2014
9,395
24,793
Derbyshire
Elddis Accordo 105
since 2014
Yes optimate is good, but open the old one up, it will only want something soldering,, ie a physical fault, all the components will be ok
davejen
davejen
1,861
1,235
Preston
Given up travelling
Since 1992
Ian
Took the back off, couldn't even see a fuse
Probably just replace it, shame really as it had just recharged my flat leisure batts from 3'4 and 3'5volts!
Cheers, Dave(y)
