Cooling fridge - which is cheaper Electric or LPG (36 Viewers)
Feb 14, 2021
4,202
9,485
Milton Keynes, UK
Burstner Lyseo 727G
3 years 30,000 miles UK and Europe.. Campsites and off Grid.
So, I need to cool the fridge on my drive prior to a trip.
LPG @99p per litre Fridge consumption 468g in 24 hours
Mains electric @ £0.225 per kwh power consumption - 240W
I could probably work it out but I'm not totally confident in my maths and electric understanding.
Appreciate some other input.
VXman
Feb 14, 2021
4,202
9,485
Milton Keynes, UK
Burstner Lyseo 727G
If it helps OP on our fridge in summer, I clocked the fridge at using 3kwh over 24 hours to cool. That was at 24 celcius outside average. I suspect it'd use rather more (around 1 kwh every 3 hours) if it was warmer as that was the peak usage.
thats 66p :oops:
VXman
Feb 14, 2021
4,202
9,485
Milton Keynes, UK
Burstner Lyseo 727G
You need a compressor fridge next time you buy one then. Mine runs on sunshine power, it's a bit cloudy today here but there's still enough solar to run the fridge AND recharge the battery 😊
This one is only 2 years old. They cost nearly £1500, I hope never to change it - will probably sell the van first.
1,254
3,056
Bailey Alliance 66-2
thats 66p :oops:
Yes, but it'd probably be more than the gas at 30 celcius with the peak usage I metered (250-300w constant), so likely quite a bit worse in a very hot period. (3 hours per kwh, so roughly 8 over 24 hours, or £1.60 in electric at 20p). I would imagine in a warm summer it would cost less in the gas used potentially at 99p a litre, and a litre being 500g.
290
997
Burstner i681
Since 2018
You don't need the other options if you have a fridge that runs reliably and efficiently off 12v. Especially if you have solar 😊
By the way, my house compressor fridge is 21 years old, ie it's been running for 21 years continuously and never broke down 🤔 you'd probably need half a dozen absorption fridges to achieve that ☺️
Nope 21 year old absorption fridge still running strong!! Well it’s had a couple of valves and a thermocouple and at one point was known as the F’ing Fridge🤣🤣
HKF
2,968
5,723
The Charente, France
Benimar Europe 740
Since August 2021
I must be a total tight wad…….
Just before I start the van…. I fill it he fridge with frozen food and everything else ice cold….. Free power from battery all the way to our destination 👍😂
That's what I do. I don't see the point of pre-cooling when you then have the door open while you're loading it :unsure:
2,415
5,167
Carado T339
5 years
The power that is used by your fridge on the road is probably the most expensive of all. It's is using a diesel engine that is using fuel that has customs charges on it driving an alternator.
I fill my freezer with pre frozen ready meals either home cooked or bought. It certainly will help to reduce the cooling costs whichever source you use.
It won't because you have already paid to cool them in your home fridge.
18
35
Chausson
What you don’t want is to cool fridge freezer day before you leave, load with food, then just before you leave, find there was a power cut during night. So have a load of half defrosted stuff just as you go.., I now put frozen stuff in the day we leave.
9,867
26,221
Derbyshire
Elddis Accordo 105
since 2014
If there's a power cut you can switch it to gas. But the house freezer will defrost 🫠
Knuckle dragger
47
27
Shepperton
Autotrail
30 years toodling around the UK
I keep some old plastic ice blocks in my freezer that chill the fridge quickly
54
159
carado
Having just undertaken major keyhole surgery (through the vents) on my Thetford fridge to replace a kaputt 240V element (& 12v whilst I was at it) I can confirm using gas would be much easier to maintain, in terms of replacing parts without having to remove the fridge, on my vehicle!!! However as others have said, you are using on board resources if you use gas. Gas is more effictive on a 3 way fridge as it gets the heat combustion chamber hotter than the 240v element does. The 240v element gets really hot though, mine lasted 9 years of heavy use!
27
29
Fife, Scotland, UK
Chausson 630
8 years
I was brought up to believe every penny counts. It's ruled my life ever since and to be fair has done me well.
I was brought up in Scotland where two of my fellow countrymen fighting over a penny, and whilst pulling said penny, invented copper wire. I have to say that I’m the tightest, most frugal sweaty sock up here and you make me feel extravagant at the very thought of pre cooling a fridge on electric. Do you shop at Tescos? Every little counts!🙄
9,867
26,221
Derbyshire
Elddis Accordo 105
since 2014
I can be quite tight sometimes, not because I'm short of money, no I enjoy it 🤑.
It's a great feeling when you get a quality item at a bargain price ✨☺️
Reactions: HKF
27
29
Fife, Scotland, UK
Chausson 630
8 years
Oh! I agree!!! I’ve been known to dance around a flag when someone I don’t know gets a bargain. I too enjoy saving money and apart from pulling VXmans leg…I too have anxiety plugging in the EHU to cool the fridge. As stated previously…it’s because I’m Scottish and worst still….a Fifer😳
1,771
4,229
mid-Norfolk
since 2006
100hp (not a lot for a diesel engine) is 75kW approximately.
A fridge is about 200W which is 0.3% of the engine power.
If you use a gallon of fuel at £6 per gallon then the fridge will cost you 18p
Gordon
(ALL figures are VERY approximate 😉)
2,415
5,167
Carado T339
5 years
Gordon
Its just for fun.
Your calculation has a large error. You are assuming both the engine and the alternator are 100% efficient. That is in turning fuel into energy and motion into electricity. In reality the engine is maybe about 40% efficient and the alternator maybe 50%.
That quadruples your cost straight away.
I reckon in terms of efficiency in cost the order is
1. Mains electricity.
2. Gas
3. Powering from the engine.
My point was that running your fridge while driving is not free. I agree it's not big money, but we were discussing pence anyway. In comparison it's the worst. I agree it's a small %
