Connecting Gaslight Propane Cylinder
Milton Keynes, UK
Burstner Lyseo 727G
3 years 30,000 miles UK and Europe.. Campsites and off Grid.
Some newbie questions relating to Gas bottels and connectors.
I've been struggling to find a 6KG Calor Gas bottle to buy for our new MH due to a shortage. We have one already but would like to have a spare onboard.
Homebase have Gas Light 5KG which will fit in our locker. https://www.homebase.co.uk/gaslight...OzVx9t5WKAxCOAzhUVgFuoS-VxkJLtxTdZSDU3t_GJoNE
However our regulator mounted in the locker is a screw on connector and this Gaslight bottle seem to be push on.
Would something like this be the solution? https://www.outdoorbits.com/gaslow-27mm-clip-on-bp-gaslite-to-218-lh-01-1673-p-948.html
Sorted!!!
VXman I've followed this thread quite carefully as we have the same problem, so was your final purchase from eBay the solution to your gaslight connection? Thanks
The clip-on connector with Gas valve in the top would have work on VXMan's set up as he has lots of clearance at the tope of his locker. I wanted to use a 10 kg bottle, so my clearance is much smaller so I used the adapter below on the connector below and all works perfectly.
I got mine from Huddersfield Gas as two separate items - however I am pretty sure it it identical to this below sold as a bundle (also Huddersfield Gas) and a bit cheaper.
But yes - good solution - all working well.
Amazon product ASIN B079X2257P
