Confused carbon monoxide alarm (2 Viewers)
Jun 4, 2020
100
158
Essex
Bailey AA79-4T
Since 2019
Hi, I am confused!! I understood that being on ehu with no gas that there can be no carbon monoxide discharge from fridge, etc.
We are on a farm CL in Suffolk with ehu, 22plate 79-4t.
Last night, however in middle of the night carbon monoxide alarm woke us up. Opened ceiling vent and alarm off we went back to sleep, only to be woken up again an hour later by the alarm again. Twice this happened.
What is going on? What is the likely problem? and how can we solve this?
Feb 24, 2013
13,461
102,811
Bolsover, Derbyshire
Hymer S800
not long enough
Does your CO detector have a display, they trigger at very low levels , but the reading could help identify source and level of reaction required
But agree with you that nothing should be creating CO other than batteries as mentioned
Lenny HB
55,939
163,325
On the coast in West Sussex
Carthago Compactline
Sounds like a knackered battery or it's being overcharged. It will be giving off hydrogen sulphide, poisonous & high risk of explosion.
Battery will probably be warm, disconnect the battery & remove from van ASAP.
13,461
102,811
Hymer S800
not long enough
Also check you have no gas turned on with heating options, our Alde will run off gas and electric at same time
Also any dip in power fridge may swap to gas
20,528
55,665
uttoxeter
ambulance conversion
50 years
Exactly what we had, didn't even know there was anything wrong with the battery but on inspection one was red hot.
meanders
Funster - Life Member
3,220
11,295
Ipswich, Suffolk
C class
Since 2004
Try replacing the batteries in the alarm.
I assume no-one nearby was running their engine. Exhaust fumes will set it off.
RayD
Jun 4, 2020
100
158
Essex
Bailey AA79-4T
Since 2019
Check your batteries, habitation & engine.
I understood that the Banner leisure battery is a sealed unit! I would expect in the current temperatures in UK, that there’s every likelihood that the leisure battery would be warm.
3,272
7,932
Ottershaw
Hymer S820
First motorhome May 2021
I think you would be able to tell the difference between a battery at ambient temperature and one which is being over charged, it will be hot, not warm.
meanders
3,220
11,295
Ipswich, Suffolk
C class
Since 2004
If the alarm has non-replaceable batteries and it's almost 2.5years old, it may simply be time to buy another alarm. To be honest, they are that cheap, it's worth doing that anyway. If the new one then alarms, you can be much more confident there is generally an issue and I regret it's then time to get a gas expert involved.
125BEER
1,218
3,316
PLYMOUTH
BENIMAR MILEO 282
Since 09 2018
Smoke detection & carbon monoxide £20 Amazon, with stick on pad...
Cheers🍻
RayD
Jun 4, 2020
100
158
Essex
Bailey AA79-4T
Since 2019
Update….
As we have 2 leisure batteries I have checked original supplied with moho. Extremely hot! Disconnected that battery.
Will purchase a new CO alarm.
So confusing, having been advised when purchasing the van from new, that it was a sealed battery that would not require maintenance!!
3,314
103,047
Shropshire
Carthago chic e-line
Since 2013
The term sealed for life is a bit misleading as they do have a 'pressure relief valve'
3,272
7,932
Ottershaw
Hymer S820
Whilst those batteries are maintenance free in normal use they have no protection against overcharging or being discharged beyond saving. You need to test the charging system to ensure the charging system is working correctly and not overcharging or the new battery you fit to replace the damaged one may also fail.
1,733
1,720
Swift Suntor 590RL
Update….
It doesn't need any "maintenance " but can vent gasses in certain circumstances such as if its being overcharged.
I would completely remove the battery from the van for safety.
1,385
2,337
Up the Hamble
Ace Siena
Since 2019
Unfortunately, not in the one supplied by Bailey.
"Supplied by Bailey" sums it up nicely. Get a proper one (combined smoke and CO - Kidde are well thought of)), instal as per instructions and see if it is still indicating CO build up before ripping out the hab battery. You never know . . . .
Two on Tour
10,802
55,744
Elddis Autoquest 175
Since 2010
From the OP, "Update….As we have 2 leisure batteries I have checked original supplied with moho. Extremely hot! Disconnected that battery."
I doubt that I would be giving a second chance to a hab battery that's getting extremely hot without checking why first. :rolleyes:
1,733
1,720
Swift Suntor 590RL
My sisters 2012 Elddis Autoquest came with an onboard charger that just gives a constant 13.8v.
To low to ever charge the battery fully so unable to de-sulfate and slightly to high for float so no good for long term battery life.
1,385
2,337
Up the Hamble
Ace Siena
Since 2019
Missed that one. Quite right. Whilst the battery clearly needs sorting, not sure that it is CO that it is giving off - interesting arcticle here: https://www.yachtingmonthly.com/gea...-may-indicate-a-battery-charging-issue-79661; and thread here: https://chemistry.stackexchange.com...o-or-can-a-co-sensor-detect-gasses-other-than
Quite a cocktail of unfriendly gases possible from an overheating battery and some of them odourless, so just as well the average CO detector picks 'em up even if it isn't CO it's reacting to.
3,272
7,932
Ottershaw
Hymer S820
There are several different methods of testing for CO inside a monitor, one type relies on a gel changing colour in the presence of CO, a light sensor picks up the color change and that triggers the alarm, it's quite possible that other gases would also cause the gel to change colour and also trigger the alarm.
