Compressor fridge (16 Viewers)
Mar 6, 2008
129
140
Spixworth
Van Conversion Moto-
Since 2006
We recently bought a compressor fridge after the nightmare 3 way Domestic 8505.
We decided on a VitriFigo C115 fridge without the freezer box.
Getting the old fridge out was the easy bit.We have a "slam dunk" door,so plenty of room. I removed some of the gas pipe then had the end capped under the van. Fitting the new fridge was err! not so easy as the fitting frame is a teeny bit big and will need some fettling later.Howevet,it looks good and works well ish!
Currently it runs for 1 minute then stops for 2 minutes. I have contacted Penguin who are the main dealers in the UK and they have said that as it is stopping the thermostat is working.We also turned the thermostat knob to 1/2 way.
Has anyone bought one of these fridges and can they confirm that their VitrFigo fridge do the same on/off routine as ours does?
Jan 19, 2014
9,851
26,182
Derbyshire
Elddis Accordo 105
since 2014
Mine is a kit I bought but with the original thermostat it did similar to what yours is doing. Is the thermostat phial fastened to the evaporator? I swapped mine for a vt9 auto defrost stat and it works now as expected.
Jan 19, 2014
9,851
26,182
Derbyshire
Elddis Accordo 105
since 2014
I put an electronic controller on it too and the VT9 stat is just a back up now.
Much better, lots of settings to faff withšŸ‘ŒšŸ˜Ž
Sep 26, 2013
4,256
5,291
Market Rasen
Self Build
Since 2003
I fitted the C85 one and it works very well just turned on to halfway, itā€™s very quiet and cannot tell when itā€™s working or not.
