Compressor fridge or replace dead 3-way?
Still playing with the fridge hoping to resurrect (or revive).
Is this what may be called a "good flame"?
The flue gets hot also the finned pipework at the top of the unit:
The bottom of the tubular arrangement and the horizontal cylinder running down the back also felt rather warm.
I had hoped to run the fridge all day from about 11:00 a.m. However, when I returned around 4:30-ish the gas had gone-out at some time and the red flashing light of doom was doing its thing. Why might that happen there's plenty of gas in the cylinders. It re-ignited immediately and the heating described occurred during the hour or so I was at the van. Foolishly I had left the fridge thermometer at home.
Do I have good reason for optimism?
If the fridge works on other power sources I would stick with it and get it serviced
I'm moderately encouraged by the results so far. Unfortunately the van is in storage at present without EHU. My driveway has a modest slope which would be along the length of the van. Does the fridge need to be level ≥3° on 240v as well as gas for happy refridgeration?
My fridge, running on gas, started to defrost. I removed the bottom vent and could see I had a blue flame a bit like yours. The thing I noticed though was that it was burning quietly. I took the burner off and cleaned the jet and when I relit it, it had that distinctive "roar" to the flame that you can hear from outside and the flame was half as tall again.
The fact that yours starts then stops on both gas and 12 volt makes me think it's more likely something else, which would suggest the pcb ?
It does burn more quietly than I expected. Is it a straight-forward job to remove the burner? Hope it's not the pcb, they are now on the unobtanium lists.
Not familiar with that particular model, but my Dometic has a burner which pulls off after removing a small self tapping screw which then gives you access to the jet which is just a thin disc with a tiny metering hole in it.
On our last van we had problems with the 3 way on gas, it had a roaring flame and looked ok, but was not cooling as it should have.
After prodding/poking/chimney sweeping and hitting with a stick, we called a Dometic engineer. He gave it a glance and said the burner is knackered - new burner. The giveaway for him was corrosion on the outside of the burner box. Telling us, if there's corrosion on the outside, it will also be on the inside. Once changed it worked like new!
Having said that, when we bought our old fixer-upper I immediately binned the existing 3 way (35 years old) and fit a 230v compressor fridge which we run from the inverter and have never regretted it!
Freezer compartment from approx 26°C to -12°C in around four-ish hours this afternoon on gas. Going to run it overnight, hopefully all will be well tomorrow. Next to try EHU when I can arrange a hook-up. Unless it doesn't need to be perfectly level on 240v, in which case I can plonk the van on my non-level driveway - and annoy my neighbours.
How long can you run the 240 fridge off grid for ?
Indefinitely for most of the year. We have done several months at a time.
It's only a small under counter fridge but an efficient one.
We have a pair of 6v Trojan 105s that can be taken quite low, a couple of 100w solar panels (tiltable for oct-feb).
We have a Victron inverter with eco mode which 'sleeps' when there is no draw on it.
I have more solar to fit as overkill but if driving once a week, no problem.
Bit of a curate's egg this here 'fridge. Cools quite rapidly on gas, but at an unknown time over-night the gas flow stopped. Flashing red light again. Re-ignited immediately and started to cool. Burner seems clean, flue doesn't dump soot when I give it a hearty "bash and wiggle". Perplexing.
Dometic are now producing compressor fridge/freezers in like for like sizing of some of their 3 way absorption fridge/freezers, but much as I would like to
swap out our poor performing 3 way absorption unit for the compressor version, I rather feel that the over £2k asking price is extracting the urine.
Especialy as a normal household fridge/freezer only cost' £200-£400 !...even with the added 12/240v options, the current pricing is i think a lot More than taking the urine !
