Hi Has the clutch fluid been replaced every year . This is essential as can lead to sludge and affect the gear changing. First place to look is your service schedule and receipts.Hi everyone, I'm new to this site but thought you may give me some clue to my fiat ducato 2017
with a comfortmatic gear box, i have a warning light and a message on dashboard saying no
gears available? HELP PLEASE
Its worth every penny to be a paid member however im sure you will get some good repliesHi everyone, I'm new to this site but thought you may give me some clue to my fiat ducato 2017
You've probably already done this but try turning the engine off and trying again.Hi everyone, I'm new to this site but thought you may give me some clue to my fiat ducato 2017
If its a Fiat isnt there a very specific way to reconnect a battery to avoid other problemsYou've probably already done this but try turning the engine off and trying again.
If that doesn't work, disconnect the cab battery, wait 30 seconds and then reconnect it. This will force the transmission control unit (TCU) to reboot. But if you have a batterymaster or some other device to top up the cab battery from the leisure batteries you will need to disconnect this first.
As other have said. Become a member and read some of the many comformatic threads. You could well save the joining fee many times over. Other than that Adams and Morley in Portsmouth are the trusted comformatic dealers I believe and that's who I used before we changed vans.Hi everyone, I'm new to this site but thought you may give me some clue to my fiat ducato 2017
Me neither did it the other day disconnect the pos and neg undo the clamp risk a hernia getting the battery out then reverse the procedureI've never had a problem when changing cab batteries.
Not sure where you're based, but, I would get it to Adams Morey at Portsmouth and get Simon to fix it...... he is a whizz.Hi everyone, I'm new to this site but thought you may give me some clue to my fiat ducato 2017
You will get away with it 9 times out of 10 but if you don't it could cost you megabucks.Me neither did it the other day disconnect the pos and neg undo the clamp risk a hernia getting the battery out then reverse the procedure
Hi lenny please explainYou will get away with it 9 times out of 10 but if you don't it could cost you megabucks.
Guess I was lucky I took the van out yesterday and all was fineCan take out the Body control module, the Airbag ECU etc.
Not worth the risk for the extra 10 min it takes doing it properly.
Having previously experienced this problem resulting in costly repair, agree with advice to sign up to MHOME Fun, read the threads and recommend as above, Simon Potter at Adams Morey. Good luck.Hi everyone, I'm new to this site but thought you may give me some clue to my fiat ducato 2017
Hopefully busy readingOP has disappeared….?
My 2013 had the same issue. I just wiggled all the fuses and relays nd solved the problem.Hi everyone, I'm new to this site but thought you may give me some clue to my fiat ducato 2017
