Comformatic confusion continues (1 Viewer)
Nov 21, 2016
42
144
Worcester
Since 2008
I read w it’s interest numerous Funsters recommending changing the clutch fluid, and only to have that carried out at Fiat maindealer garage where they have the necessary diagnostics and appropriate equipment
So I just called my nearest Fiat maindealer garage, to arrange an interim service, MOT and Clutch fluid change. The Service technician was most helpful, agreeing that they could certainly carry out the work, BUT, …..he asked if I had read about the clutch fluid change online. He then said that if the gearbox was behaving ok, then he would seriously recommend not to “meddle” as his experience was that sometimes the action of carrying out the work could end up with serious implications, with a frightener of up to £7500 risk.
I understand that it is right to make me aware that there are risks, and maybe he does this to cover themselves that at least we were made aware in advance,
So my gut is to take his advice, no clutch fluid change unless or until the gearbox starts to cause problems.
I wonder if anyone out there has good or bad experiences that may guide me.
Dexter
Dec 2, 2019
4,095
9,148
South Lincolnshire
Rapido 7065+
Broken most bits now
Fiat can never agree with themselves when to change it but the majority of Fiat manuals say change every 2 years which if done by grown ups shouldn't cause any issues.
May 31, 2015
11,686
44,546
Cornwall
Ducato PVC
Getting Better
The dilemma is who is right…🤷🏼‍♂️ a few (and only a few) fiat dealers say do it every year and Adam’s moray is making a few bob out of his advice…. But the mains census is that fiat don’t even know as there vehicle handbooks have changed…
My ducato has 126,000 miles on it now (as far as I’m aware) hasn’t had a gearbox oil change….🤔
Dec 2, 2019
4,095
9,148
South Lincolnshire
Rapido 7065+
The gearbox oil is a different system to the Comfortmatic stuff and should be good for life - or about 150k miles
Lenny HB
53,491
150,266
On the coast in West Sussex
Hymer B678 DL
By then it's too late and you will be into a repair bill of between £2000 to £5000
Dexter
Minxy & Oscar & Kannon Fodda have recently had expensive clutch repairs due to contaminated fluid.
That is not correct Garry, Fiat recommend changing the fluid every 2 years. Simon the service manager at AM agrees with Fiat but he changes the fluid in his own van annually.
You seem to be happy not spending £130 on a clutch fluid change against the risk of a £2000 to £5000 repair bill, not a risk I was prepared to take.
Also when was the kiss alignment last done on your clutch as that needs doing regularly to avoid problems (it's done when they do the fluid change).
May 31, 2015
11,686
44,546
Cornwall
Ducato PVC
Getting Better
I agree with you Lenny, I’d like to get the oils done but you do hear of “it can cause a problem if you have it done” my van is running really sweet and I’m constantly monitoring the box and gear changes to a point of obsession…
I’m in two minds… I’d thought I’d wait a little while and see if anyone has a problem who has recently had the oils done….🤔
Lenny HB
53,491
150,266
Hymer B678 DL
Nearly everyone who has had it done comments on smother gear changes and more responsive changes me included. It's probably down mostly to the kiss point realignment which most dealers don't do on a service because they haven't got a clue.
WESTY66
5,835
14,284
South Yorkshire
Carthago Chic C-Line
All the gear, and no idea!
Spot on Lenny, that’s what I’ve found, I’m very happy I made the trek down there to have it done, it’s a lot smoother on take up now which I agree is probably down to the kiss point re learn👍👍
Dec 17, 2019
1,031
1,818
St Leonards, Dorset, UK
Carthago Malibu
Converted caravanner!
Had ours done for its 4 year service. Don’t see the benefit of not having it done and then creating a potential problem, which then everyone denigrates the comfortmatic system?
May 31, 2015
11,686
44,546
Cornwall
Ducato PVC
Getting Better
I’ll be up your way in march and I’ll probably book it in for then….
Jun 14, 2014
1,453
3,105
Coventry
IH N680CFL
Since2014
My Ducato Comformatic had 20k on it and was fine and is now somebody else's problem. :xrofl:
Minxy
32,672
66,635
E Yorks
Carthago Compactline
@Minxy & @Oscar & @Kannon Fodda have recently had expensive clutch repairs due to contaminated fluid.
Ours wasn't caused by contaminated fluids, the clutch cylinder was leaking, we collected it this morning and were given the parts back.
TheBig1
17,635
43,369
I got my van used and with a good service history, which I continued to the schedule fiat put in their books at the time. The hydraulic actuating fluid had never been changed and it turns out contamination leaks in past seals. The upshot was a total loss of gears and the slave cylinder dumped fluid onto the clutch. The mechanic that took it apart first thought it had lost all fluid. It was like treacle though. £2500 later I got it back and it packed in again within a year and other than a replacement seal was covered under the warranty. Thankfully I have breakdown cover, which despite being with the RAC was handled by HGV specialists both times. HGV breakdown and transport is measured in thousands of pounds and only a few places do it. Not getting mine changed again this year if I can avoid it, but it will be done next year regardless. I was very lucky to have broken down both times within 25 miles of my local Adams Morey and within 10 of the Portsmouth branch. I wouldn't trust a backstreet garage in an unknown area to gamble whether they were capable of doing it right. It's not a simple process and getting it wrong is what causes problems
As for leaving it till it breaks, you are then pretty certain it will cost a few grand to fix and who knows when? To misquote Dirty Harry Do you feel lucky this holiday?
Minxy
32,672
66,635
E Yorks
What did they replace?
Clutch kit (1666756980) @ £310+VAT and slave cylinder (55251546) @ £100 +VAT, then they flushed hydraulics & calibrated. They actually discounted the parts as their list prices were £347 & £130 +VAT respectively. The labour/other costs came out at £1057+VAT, grand total of £1467+VAT = £1760.
