Cleaning the white seal above the cab windscreen (1 Viewer)
Aug 20, 2018
52
28
Burstner Harmony Lin
Since 2018
Hi Funsters can you tell us what to use to get clean up the white silicone sealant that has gone black above the windscreen between the cab and the coachbuilt bodywork on our Burstner? We’ve tried WD40 and pink stuff
Dec 5, 2022
131
117
Lichfield, UK
autotrail navajo
4 yrs
can I ask another question relevant to this thread, I need to reseal mine between overhead cab and windscreen, any body got recommendations based on experience what sealer to use?
Apr 19, 2019
2,289
4,847
Carado T339
5 years
Long arms help as well.
Aug 17, 2020
207
313
Leicestershire, UK
Pilote
Since 2011
I used sikafix 522 caravan when I did mine a few years ago
Search on here others prefer other makes and versions.
Dec 5, 2022
131
117
Lichfield, UK
autotrail navajo
4 yrs
Thanks wonders, just got to work out how I'm going to build a platform so I can reach the centre 😀
Aug 17, 2020
207
313
Leicestershire, UK
Pilote
Since 2011
I managed it with steps next to front wheel and stand on top of tyre and steps. Reach across from each side to middle with sealant gun. Smooth bead withe finger withe small amount of washing up liquid to smooth. (y)
Apr 9, 2018
8,684
44,917
Worcestershire
Bailey Adamo 75-4t
March 2018
Bumping this thread as I need to clean some silicone seals that are brown or even black from dirt.
Going to try some spray kitchen cleaner unless anyone has a better method.
Apr 20, 2020
1,080
2,360
Northern Ireland.
Adria Compact SC.
Since 2017
I had a lot of dried on flies on the front of our motorhome last spring so used a bug remover spray. (sorry cant remember which one)
It also made the white sealant look like new.
(Note - apply to a small sample area first and don't spray onto graphics etc)
May 15, 2022
784
2,259
Bavaria
Pilote P969D
Since 2012
Silicon Entferner by Mellerud................Silicon cleaner from Mellerud...I get it from Amazon, does a good job, used it a lot on the last MH as the silicone seals were of the poorest quality...
Apr 3, 2019
1,519
2,781
UK
Burstner Travel Van
Few years now
I apply bleach using an old toothbrush. Leave for 30-40 mins and then scrub it all off.
Feb 22, 2020
344
1,007
West Midlands
Bessacarr E582
2011, 11.6m cruiser on Thames for 5 years before
A ladder with plenty of foam/sponge padding against the front of the van, with the base against a wall or post to stop it sliding away. Should be strong enough to let you crawl up; I had to do this to seal the overcab skylight.
