dawsey
I also spoke to Roamer and KS Energy. Roamer guy told me I needed to place pretty much all of the electronics in my motorhome to use a lithium battery which sent me off speaking to motorhome installers who were utterly confused with what I was wanting doing so I had mostly given up but then I spoke to KS energy and they said their battery would work just fine with the equipment I had and I installed it and so far it has been absolutely amazing. I basically swapped out my old battery for the LS Energy battery and now we are drowning in power and I can run a 3kw inverter Very happy.
Be very wary of overloading the alternator, and/or blowing the fuses or maybe the Electoblock due to overload (if not using a B2B). Unlike Lead Acid, Lithiums have low internal resistance and will take whatever the alternator can supply. Lithium batteries would likely also not take well to long journeys where they reach full charge and are then held at the 14.4V of the alternator as opposed to their float voltage, it may well seriously damage them in the medium to longer term, and will almost certainly reduce their life.
Charging lithiums via the old split charge relay system is going to, sooner or later, compromise the Alternator and its wiring, the elektrobkock and the batteries. One or all will fail early.
The safe solution for older campers is to charge the lithiums via a B2B connected between the starter and the leisure batteries, and use a 50A ideal diode to discharge the leisure batteries via the normal 12V control block (eg the Electroblok). EHU won’t charge the lithiums, but it doesn’t need to.
