Silver-Fox
On Caddy, check under the rear bench seat for the fuel sender. You should have a pick up there, or at least access the pipes.
Those are not specific vivaro quick disconnects. They are industry standard. I believe most if not all manufacturers use them.Done some searching but couldn’t find an aftermarket adapter like Gromett linked to.
Results just seem to be about Vivaro and it’s sister vans.
On my tank , which is on a Peugeot base there is an inspection cover with all the pipework going into the top of the tank. There is an elbow which I believe is a breather pipe and can be pulled out ( held in place with a short bolt) and replaced. I put my fuel pipe off take for my deisel heater through this.Gromett
It’s a 2004 VW Caddy SWB van 1.9tdi.
Any help would be great as I’m not keen on drilling the tank to be honest.
Gromett
I was thinking it was van specific
Gromett
What make, model and year is your vehicle. I will see if I can find out for you. If not you will probably have to look at the van itself to find a suitable point to see if there are those style of connectors.
I know they were around from 2009 and perhaps before?
Sprinter W907 (2018+)If it works for you, can you let us know what make/model van you have and which adapter you used and the location?
May be useful information for others? Thanks
Did you make any progress on this by any chance?Gromett youre a star.
Next time she’s over I’ll have a dig around her van and see what I can find.
Hopefully I’ll find that connector and all will be good.
I understand what that the one you’ve linked may not be the correct one but you’ve put me in the right direction.
I have to admit I was getting nowhere fast.
Once again Thankyou will report back with findings.
