I've found what looks to be the unit Dimatec push 12v. The silver cover can be gently prized off to reveal 3 screws. Not got further than that yet but suspect Lenny HB is correct in that it's a new unit required rather than a bulb change.
I had a similar ‘touch’ light go defective just recently on our Adria recently - one of a pair on the opposing B pillars - and they’re not readily obtainable other than from the manufacturer, and you can guess how much that would be and how long to arrive.
Aliexpress came up with a pair of almost identical replacements for less than £10 that also have a touch dimmer function, and were delivered in 7 days.
Just a quick response as the replacement units have arrived. They are definitely a full unit replacement but should hopefully be a simple swap. The bezel is a different finish but I can use the original for that so they will still all match.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
