Central locking (1 Viewer)
motorhomeman 01
uk
since 2010
hi, all, has any one had trouble with there central locking on a 2007,Lunar Champ A511, as mine has now started to blow fuses, and the passenger door is locked and cant be opened from the outside, thanks.:Sad:
43,332
49,505
hi and welcome.....
could be many things but most likely a trapped/chaffed wire is shorting to earth and blowing the fuse.
could also be the actuator/motor has burnt out or the mechanism has jammed and is overloading the fuse.
you need to get to the motor/actuator to check if it moves manually when pulled/pushed and the wiring to see if theres any obvious damage.
DESCO
2,646
266
London
low profile
18 years +12 years tugging
hi and welcome.....
I had this happen on our car, as said by pappajohn turned out to be actuator, a little lubrication carefully applied to moving joints cured the problem.
Sorry forgot to say welcome
scran
701
83
washington
a class
we had problem when we bought our pilote it was the wiring on the hab door near the hinges neede renewed hope this helps:Smile:
M
motorhomeman 01
uk
since 2010
hi and welcome.....
hi, thanks for getting back to me, i thought that, i am taking it into camper uk next tuesday, i just hope it does not cost to much, if it is the motor/actuator.thanks for your help.
