Or bin Windows and run Linux Mint it would run a treat. You wouldn't need to buy any extra memory either! You could always load Linux from a USB stick to see if it meets expectations before you take the plunge or parallel install it.
Personally I run mac hardware but I do get a lot of calls for help from friends as I work in IT.He has Windows 7 and a Dell Inspiron 1524, 2 Gig memory, I have stripped everything off thats not required, run CC and found loads of issues with the registry, all now fixed, run Malware Bytes, found some issues, all removed.. Its still running slow, Task Manager CPU 100% memory fully used..
I am tempted to reinstall Windows... He only uses it for his snaps and surfing... Dont unserstand the high CPU use.
What the heck is that ... your Dad hasn't been licking the monitor has he!!!Looked at taste manager processes running abd using CPU svchost. Executive appears to be hogging the CPU.
bleeding phone.... task managerWhat the heck is that ... your Dad hasn't been licking the monitor has he!!!
Some info about SVChost.exe here which might help:Looked at taste manager processes running abd using CPU svchost. Executive appears to be hogging the CPU.
