Cassette question (2 Viewers)
Nov 1, 2023
112
2,962
Adria
The large circular hatch on my cassette has decided to become immovable so I can't twist it off to get inside to thoroughly clean it
I don't want to force it & break the thing
What would be the best product (spray?) to ease it.
I'm a bit loathe to use WD40 or Vaseline as they can sometimes do strange things to certain materials
What do you suggest?
JockandRita
11,516
150,911
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
Nonna, as the old saying goes, ie, a photo speaks a thousand words. ;)
What make and model of cassette do you have, and exactly which part are you looking to remove, eg, the plate which holds the rubber seal, or some other part?
Cheers,
Jock. :)
Apr 22, 2018
6,849
12,626
Herts.
Adria Coral lowline
Silicon spray if you feel you need lubricants.
If you make a lever from a piece of wood that fits between the two channels that will give you a bit of leverage to open it. With silicon spray on the o ring when refitting will make it easy next time.
Nonna
Nov 1, 2023
112
2,962
Adria
Cheers,
Jock. :)
Sorry
I realised too late that I should have said it's a Thetford
It's the plate which when removed leaves a, say, 6in opening
Nonna
Nov 1, 2023
112
2,962
Adria
I'll try to hunt down some suitable wood & some silicon spray
JockandRita
11,516
150,911
Lincs/Cambs border
N+B Flair 8000i
If it's tight that doesn't work you need a length of timber.
Once out grease the seal with silicone grease to make it easier to remove in future.
But we still haven't established what make and model of cassette yet. Never in my days of caravans and MHs, have I needed to apply a piece of timber to gain access to clean a cassette. 🤷‍♂️
Which make and model are you both referring to?
Edited..... Just seen Nonna's reference to David"s video link, and all becomes clear. (y)
Cheers,
Jock. :)
Nonna
Nov 1, 2023
112
2,962
Adria
Thanks. Grease as opposed to spray?
Apr 22, 2018
6,849
12,626
Herts.
Adria Coral lowline
Spray or grease is ok once open, but spray around the joint before opening may help. Grease won’t until apart.
Howard H
4,834
4,798
West Lancashire
Benimar mileo 294
Some times as I found out it just will not budge and even using spray and making a piece of wood to fit the runners . I had to butcher the whole ring to get it out but you can buy the whole round assembly including new seal for about £45.
Nov 13, 2011
1,487
3,546
30 years
Plastic responds well to heat, so try some boiling water dribbled round the seal, it should then turn .
Geoff
Apr 26, 2015
2,839
7,030
Ottershaw
Hymer S820
First motorhome May 2021
On no account use Vaseline or any other petroleum based products, Thetford make a silicone spray specifically for use on the seals it's £7.00 on Amazon.
JockandRita
11,516
150,911
Lincs/Cambs border
N+B Flair 8000i
Been using the stuff successfully for years, on toilet seals, awning assemblies, hydraulic levellers, electric steps, door hinges, locks, and latches, etc, etc.
There is nothing special about the Thetford product, just like their internal cleaning fluids, ie, I've had better results with a good soak using a citric acid solution to clean/descale the internals of the cassette, with no damage to the working parts, or seals. (y)
Cheers,
Jock. :)
