It's not... its completely corroded away at the end where the gas jet injects into the burner box. The tube inside the box is just flapping about. I'll get a picture.Well done!
Not easy to offer an opinion on the burner without a pic. I've not done anything to mine except a superficial clean. Cosmetic corrosion of the burner assembly isn't likely to cause any issues so long as it's intact, the jet is clear and the burner lights along its length. The actual burner isn't connected to the gas supply. The gas exits the jet and 'spills' along the underside of the perforated burner.
If it's working O.K. I'd just clean out any dust and general detritus as from past experience once one starts fiddling unnecessarily one can end with sheared screws, new gas leaks etc. and a lot more work than inteneded.
No it seems the gap is normal, but it looks like there should be a wall with a hole in it on the side of the box closest to the gas jet. That's corroded away on mine, and that tube seems to be just flapping about inside the box.I thought that there is a gas connection to the burner, but it's not difficult to replace
O ring was the first thing I did. Burner box ordered now. I think it's for the best.Ah, (our posts crossed) I've not had my burner box off so no idea about the 'tube inside' (maybe the design changed over time?) but the box itself looks reasonably serviceable - maybe a light wire brush off. However, since it's a potentially dangerous gas component and it seems there should be a secure internal tube I would replace the burner box.
The thin metal internal plate that covered the burner and is removed in these pictures, unfortunately the screws sheered off when removing it. For now I have just pushed it back into place. Does this pose any issue? Is there I way I could maybe create a new way to fix it back into place. Has anyone else had a similar issue?
