Marten
- Feb 3, 2024
- 30
- 33
- Carthago Compactline
Hi all. I wonder if anyone can shed light on an electrical mystery. My 2018 Carthago Compactline (Ducato Chassis) has developed an issue that is baffling me.
The Starter Battery has begun going flat without EHU after about three days unoccupied. I presume it is shot and a multimeter across the terminals confirms this with the Starter Battery at just over 11v and the Leisure Battery at approx 14v
But here's the thing.... the control panel in the van shows the Starter battery as full and the Leisure battery as nearly dead. Definitely. Checked and re-checked.
To back up this seemingly backwards reading.....without EHU, and with the habitation lights and TV on, the Starter Battery drains even faster (just a few hours.) Meanwhile the Leisure Battery remains on approx 14v. My understanding is that this shouldn't be possible.
I have a solar panel and a split charger controller on it, but that on it's own evidently isn't proving enough to keep the Starter battery topped up enough without EHU.
I suspect I will have to take it to a specialist and I'm sure they will explain / fix it, but I would like to be able to go with a bit more knowledge and make sure that if there is a bigger issue, they sort it out, rather than just supply a new Starter Battery.
Has anyone had a similar experience ?
Many thanks.
Marten.
Many thanks.
Marten.
